Question about Mesh Express TV PC Desktop
INTERNAL SATA DRIVE NOT BEING RECOGNISED
HI I HAVE A MESH DESKTOP WITH WINDOWS HP HOME. IT STOPPED RECENTLY AND TRIED TO RECONFIGURE TO FACTORY SETTINGS BUT IT SAYS NO MASTER DRIVE DETECTED. I THOUGHT IT COULD BE HARD DRIVE FAILURE SO BOUGHT A NEW SEAGATE BARRACUDA SATA DRIVE AND CONNECTED. NOW IT SAYS NO HARD DISC DRIVE DETECTED AND BIOS NOT INSTALLED. NOT SURE WHAT TO DO. DON`T KNOW HOW TO INSTALL THE BIOS AND DON`T KNOW FROM WHERE TO GET IT. THANKS FOR UR HELP
    Sergeant:
  • 361 Answers
If u search in google you can get methood and b ios softwere. plese once atime change pata cable to look
Posted on Jun 28, 2009
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
Reboot problems
Hi Dear,
The problem you discussed is hardware related, IT has to do with the cmos battery or the Sata cable.
Disconnect/Connect CMOS battery and reconfigure BIOS settings again based on defaults
- Replace "ALL" SATA Cables and reconnect all drives
Regards
Samson Ved
Oct 18, 2013 | Gateway GT5670 Desktop PC
Hard disk is not boot up after windows screen appears
It seems you computer is not recognising the hard-drive, on boot up, because it doesn't know where to look, i.e. it is booting up to a different drive letter. Have you got more than one drive on the system? If you have you will need to reconfigure the bootup list. Good Luck. George
Mar 29, 2013 | Fujitsu MHW2120BJ-G1 Hard drive 120GB...
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
I recently had a hard drive failure on my HP Pavilion a610n. I decided to replace the IDE drive with an SATA drive. However, the computer will not recognize the SATA drive. I have tried plugging the SATA...
I'm not sure you can insert your OS disk to istall or not, so the solution depends on your being able to do so. It seems to me there's a strong possibility that the BIOS cannot see the drive because that software had basic drivers to recognise the IDE Drive the computer came with.
So, you have to locate the SATA Driver which can be loaded during installation of the OS from either a boot cd or boot floppy. WIndows Setup gives you a chance at the beginning of setup if you watch the progress bar below to press F6 if you need to load a "Third Party or RAID driver" A little further along the setup will stop and prompt you for this driver and you'll need it ready with the exterior CD drive or floppy drive attached with the media in it to load.
It's quite possible this is what you're going to have to do. If this isn't the solution, please don't trash my rating with a thumbs down click. I'm trying to help without complete info.
Best Wishes
Aug 03, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
Hello'I' gt a compaq d330 ut desktop Pc to arrange
If you format the hard drive NTFS format you should be able to install Windows XP. If the computer is old, the hardware may not work with Windows XP. Any computer built in last 8-9 years should work with Windows XP.
Nov 08, 2009 | HP Compaq Business Desktop d330
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
Hp laptop having CPU T8100 or above and windows XP professional
Try this model in HP - HP Pavilion dv9700t CTO Entertainment Notebook PC.HP ? Intel Core 2 Duo T9300 Processor (2.50 GHz, 6 MB L2 Cache, 800MHz FSB) ? 17.0" WSXGA+ High-Definition HP BrightView Widescreen Display (1680 x 1050) ? 512MB NVIDIA GeForce 8600M GS ? 2GB DDR2 System Memory (2 Dimm) ? 240GB 7200RPM SATA Dual Hard Drive (120GB x 2) ? 32-bit Windows Vista Home Premium Webcam, fingerprint. Call to this toll free number : - 1800 42 54 999 for HP reseller showrooms.
Jun 06, 2009 | HP RP5700 POINT OF SALE E6400 CPU 80GB...
Mesh Express TV  PC Desktop Logo
136 people viewed this question
Top Mesh Computers & Internet Experts
Sandeep Kumar
steve s
steve s
Glyn
Are you a Mesh Computer and Internet Expert? Answer questions, earn points and help others
