Question about Dryers
Does the Admiral Capacity plus have a reset button anywhere on it. My dryer suddenly stopped only a 4-5 yrs old, great condition. The inside light as well has gone out. It was all ar once no warning
  • 1 more comment
  • lannh0865 Jun 28, 2009
    On the top of the back wall? I am a little confused, so do I need to take off the entire back cover to get to it.?
    It appears that the only thing that you could possibly take off is the back top plate (metal/silver) and look for the fuse there. Is that where you mean to go. There is no way to take off the cover in the back of the dryer, there are bolts here and there but a complet;y smooth surface so the only thing I see is the top back (possible) and on the back at the bottom next to where the vent comes out there is a hole the size of a quarter but I cant tell what it is or if there is a button there as I have not completly pulled the dryer out as it is in a tight area.
  • heatherholts
    heatherholts Oct 21, 2012
    What kind of fuse does it require and where do you buy a new fuse?
    Genius:
  • 1,122 Answers
The dryer has a main fuse under the top on the back wall,if that is blown nothing will work,also check the breaker box it might of tripped,-mike
Posted on Jun 28, 2009
  • MIKE major Jun 28, 2009
    inside on the back wall beside the heater,it's a little round fuse
    did you check the breaker box?do you have a meter to see if the dryer is getting any power since the inside light is off,check both legs on the back powercord terminal block-mike
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
I'm trying to install a 4-wire system electrical
Hi heathvaneato...
Go to the following webpage and you will see a picture and description of how to wire your dryer.
Please take time to rate me thumbs up.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.ph
Sep 23, 2011 | Admiral AED4475TQ
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Jan 07, 2010 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
How do I remove front panel of my Admiral Capacity Plus washer?
The front panel does not come off.
To access the inside - there are a few screw on the back - then the shroud is removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
Admiral Capacity Plus Dryer won't start. No light when door open. Plugged in, Circuit Breaker Reset, socket live, (tested). Internal fuse or circuit breaker?
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Sep 22, 2008 | Dryers
Dryers Logo
897 people viewed this question
Top Dryers Experts
