Question about Polaris 380 In Ground Pool Cleaner
Unit floats does not run on all wheels
My unit runs on front wheels and kinda floats instead of running on all wheels
I had the same problem. 380 was running on its front wheel waving its tail in the water.
The cause was the o-ring number 31 on parts diagram was passing water and insufficient flow decreased suction. That's why polaris was not sucked down to the pool floor. The solution was to disassemble the 380, re-seat the o-ring and to re-assemble it.
Also I noticed the wheels on 380 weren't spinning well. That was caused as part number 2 got deformed from age and was rubbing on the turbine wheel 19. A solution was to scrape off some plastic from part 2 where it was in contact with the turbine.
After reassembly and adjusting the nozzle number 21 to the 11 o'clock position the 380 started running well.
Posted on Apr 02, 2010
    Problem Solver:
  • 10 Answers
Sounds like it might be missing the head weight. Check for number 25 in this Polaris 380 Parts Diagram
Posted on Nov 05, 2009
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My zzr is leaking fuel at a steady rate from the hose that empties out in front of the rear wheel, there is poor response from the throttle at low revs and does not hold idle. its as if its running far too...
It is flooding. Check for a float sticking or a needle and seat sticking open. It could also have a hole in a float that is it keeping open. (The float could be full of fuel and failing to float).
Jul 31, 2011 | kawasaki ZZR 250 Motorcycles
Used descaler yesterday, as pump was running for along time, this am motor is running continuously.
After turning power off to unit, open unit and locate float switch. Switch may be stuck in up posistion which will cause unit to run constantly. If float switch is down than switch will need to be replaced.
Jan 28, 2011 | Saniflo Home
My polaris runs but there is no suction. Any recommendation?
Inside the part where the bag clicks onto the large circle outlet on the top are two little valves. Sometimes these get clogged by algae. Use a thin wooden skewer to poke the algae through then replace your line hose onto the pool return. Everything should work now.
Apr 16, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Just bought a 2003 2500hd with 48000 miles. how often are the fron wheel bearings serviced and can or should synthetic oil be used in this engine ( 8.1 ).
I wouldn't recommend using synthetic oil in an 8.1 because they are known to use 1 to 2 quarts between oil changes and its kinda of a waste of expensive oil.. I always run 10w 30w in these engines. front wheel bearings.. they are non serviceable or packable they are a sealed hub unit. Inspection is raising the vehicle to where the front wheels are off the ground and shake them top to bottom when you feel play, they are due to be replaced they usually last 100k miles or less..
Mar 31, 2010 | 2003 Chevrolet Silverado 2500HD
How do you bleed the abs unit on a 1997 chevrolet truck
start by bleeding the master cylinder bleed the line closest to the fire wall, then proceed to the right rear wheel, left rear wheel, right front wheel, and then the left front wheel.
Sep 16, 2009 | 1997 Chevrolet Malibu
The AC is on and it says it is 86 in the house and cold air is kinda blowing but it is HOT in the house.
Check outside unit to see if running if not check breakers and see if there is float switch inside the air handler inside. There is only so much you can do. Calla service tech for free estimate. Russ
Aug 15, 2009 | Heating & Cooling
My bike is running backwards
kinda creepy.
set the engine backwards too, making it cool for a front wheel drive bike :)
Aug 12, 2009 | 2004 Yamaha YZ 250
Taking of steering wheel.
it hard to take of the the wheel cause of the air bag but it would be an easy way just to get the car tracked and that will put the wheel stright agin
Mar 17, 2009 | 2001 Volkswagen Passat
Polaris 380 In Ground Pool Cleaner Logo
560 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
