PC does not boots
My Desktop PC does not boots up sometimes and if it boots also it restarts after 5 mins I am not able to proceed please can some one help me.
Current Problem:
My hard drive is empty and does not have any contents in my hard disk So I want to install the Windows XP operating system to my system.
Now if I insert the CD and start the system all the fans will be running and the the display does not comes up in the moniter. After it starts it will reboot after 5 mins even if I enter to BIOS setup and stay in BIOS screen it reboots after 5 mins.
Please can some one help me to resolve the problem.
My System configuration:
Intel 845 GBV mother board
1 GB RAM + 256 MB RAM
80 GB Hard Disk
On board video is not working so I am using 8 MB NVIDEA graphics card
Please do reply to me !! I will be waiting for the reply
  • 2 more comments
  • guru_bh Jun 28, 2009
    Thanks for your inputs I have tried to remove all the components and tried connecting only the mother board with power supply and check the display.
    Still it dosent work but sometimes it boots up and works fine.
    I have tried even dis connecting the hardware parts by one by one but still I was not able to find what is the problem.
    If you have some method to find out which is the faulty hardware I can try to find that.
    One more question is what is the voltage and ampere needs to come from the SMPS ?
  • guru_bh Jul 01, 2009
    Hi Checked my SMPS manually as I dont have one more system to check with another SMPS, the voltage what is comming is right and when I connect my SMPS to a FAN and short the green and black wire the fan runs without any problems :)
    So is there still problem in the SMPS ?
  • 3,267 Answers
Change the SMPS, preferably with 450 & above wattage. Also you must be using an UPS(uninterrupted power supply or battery back-up so there are no chances of voltage fluctuation. At the time of changing the SMPS also remove the RAM and clean the contact points with a piece of normal white paper..............sodeep
Posted on Jun 28, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Jun 30, 2009
    Since you seem to be unwilling to change the SMPS, try lading only 1 RAM in any slot, switch slots and see if it has any improvement on the PC behavior. Both RAMS should same FSB, i.e. "Bus Speed", otherwise it will behave like now. Ensure that both RAM have the same FSB(133, 266,333, 400, 667,800,............) and simply try at least a working SMPS, borrowed or whatever. My experience in this kind of situation, if both RAMS have same FSB's, simply replace the SMPS which probably costs, max. 5 bucks. There are various voltages coming from the SMPS( practically 6, if one counts the -ve voltage too and a tolerence varies from maker to maker.
    Try this once and if it does not work feel free to curse me(hope not)..................sodeep
    Sergeant:
  • 361 Answers
In my experince it is a ram fault change a new ram to check once atime. 2/ some times some parts of computer may be sort .as modeam and graphice card. took out them and check one by one.
  • Roshan Rijal
    Roshan Rijal Jul 12, 2009
    some time bootable virouse can not give to boot.took out hdd and formate on another hd . then it can work . ihave face same problem and solve ,
2 Suggested Answers
  • 70 Answers
SOURCE: PC does not boots / does not start
Since your system reboots even if you stay in the Bios setup the problem with your system might be because of heating up of the proceesor, which might be caused if the fan CPU fan is rotating slowly or is not rotating at all. If the fan is rotating slowly change the cpu fan and try to reinstall XP
Posted on Jun 29, 2009
I own a dell 1501 and i keep getting delete restoration data and proceed to system boot menu or continue with system restart..help
hi my name is rui
try formating your HD then reinstall your OS this might fix your problem it sometimes means that you hava some components missing so it prevents windows to not start up.
pls rate my comment tnx.
Jul 22, 2011 | Computers & Internet
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
Computer booting up. at least 5 min. or more.
You can use the following link to check , why the computer is giving performance issues.
http://tinyurl.com/29w3pgr
Slow system performace could be caused due to multiple issues . Namely less free space on the hard-drive, too many startup programs, virus or spy ware.
Thanks for using Fixya
Proton
Jul 28, 2010 | Dell Dimension 2400 PC Desktop
I have latitude CPx500GT can you plz tell me unlocked a administrator password.... Thnx..
hi, unplug the pc- remove the lithium battery on the board-find the jumper on a three prong header-move it 2 the reset bios position-push the power on button, or wait 5 min-then put it all back to the way it was-then boot up.. make sure you set the correct values- bus speed-boot order-time and date-ect. if you need further help-reply. good luck! and please rate this solution. be well!
Jul 12, 2009 | Intel Motherboard
Jun 29, 2009 | Computers & Internet
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Getting hanged
try to boot into safe mode by pressing F8 while restarting..then in safe mode goto>start>Run>type msconfig>and in start up tab disable the un necessary programs...then restart
Apr 11, 2009 | Acer Aspire 4720 Notebook
Problem with MS 7057
Hi, when you get it to desktop go for a system restore to an earlier date
thanks
Aug 16, 2008 | Acer Aspire SA20 PC Desktop
Acre 5520 laptop
Assuming already installed vista.
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Is it giving any error messages.
Try booting in to safe mode.
If it does then the issue is with something.
Do you have two video adapters.
Try boot from the dvd & run the recovery for vista.
or the system restore from the dvd.
At last run repair reinstallation using the vista dvd.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
Acer Veriton 6800 PC Desktop will only beep will not boot.
Hi Just checking first of all you have tried another memory module. This sounds like a faulty RAM. Please try and get back to me if that doesn't fix it. Thanks, Lolita
Jun 02, 2007 | Acer Veriton 6800 PC Desktop
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
