Question about Honeywell HZ-709 Oil Filled Radiator Heater
When I turn the heater on, it operates for a few seconds, maybe up to 10, but then when I try to change the temperature, it shuts off automatically. It happens again and again.
  • Anonymous Nov 15, 2007
    honeywell HZ-709 oil filled radiator heater... cuts back off as soon as i cut it on... help .. need heat!
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
Operating instructions
I need to download direction for the Honeywell oil filled radiator heater hz709 please
Oct 18, 2013 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell 709. tried to move to another room. forgot to turn off before pulling out plug. wont start. plug is ok, works for lights. wont turn on. what do i do ?
let sit overnight, most likely disturbed the internal t-stat.The oil has to settle again. And make sure power oi off before turning on.
Apr 01, 2011 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
1,129 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
