Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
1982 palamino colt wood top rotten
How to replace top
How do I repair the rotten wood on my deck
Once you have dry rot in a deck it is very hard to stop completely. It is a fungus, and spreads tendrils in the wood grain. Repairs have to involve chopping away all the rot to sound wood, and then treating it. Simply painting it with something s ineffective.
There are many commercial fungicides, all poisonous, so take care. A popular DIY treatment is a mixture of glycol (concentrated auto antifreeze) and borax, with a bit of liquid soap.
There is usually a lot more rot than meets the eye, often in the joists and bearers. The strength of the decking can then be compromised, and if concerned, ask a builder.
You are often best off just ripping out the whole lot, and replacing it with preservative treated timber which will never get the same problem.
Aug 09, 2016 | Garden
OLD STURDY ENTRY DOOR, THE HINGES ARE LOOSE BECAUSE THE 2"X3" STUDS THAT WERE USED FOR DOOR JAM OR FRAME ARE ROTTEN, I DO NOT WANT TO REPLACE DOOR JUST THE WOOD THAT HOLDS THE HINDGES, PLEASE HELP ARE
Usually there is a wood trim that is 1/2 inch thick that is put over the STUDS that make up the frame around the doorway. IF you take the door out, then you can take out the trim and see if the studs are ok. OR you can just get really long 2 or 3 inch screws to replace the ones that are holding the hinges to the trim. The long screws will go all the way into the studs.
Mar 13, 2014 | Black & Decker TROS1000 Toaster Oven
I have rotten wood under my roof the roofer failed to replace How do I repair it?
I would ask someone who does <a href="http://affiliatedroofers.ca/services/">Vancouver roof repair</a> that I know of. They should be able to tell you.
Oct 25, 2013 | Senco Scn40r Roofing Coil Nailer Repair...
I had a new roof up on my house about 6 years ago. I just went into my attic and found wood that was rotten and was not replaced by the roofer. How can I replace the wood?
that would depend on if what you wish replaced are rafters, trusses or sheeting. rafters and trusses can have new pieces cut to fit and 'married' in bridging any weak areas. unfortunately, sheeting replacement means stripping shingle and paper to expose the damaged areas, cutting them out, new sheeting installed, repaper and reshingle. Hope you got a warranty from the contractor.
Oct 25, 2013 | Dometic Rooftop RV Air Conditioner
1982 yamaha 550 top end
You cannot get replacement pistons, they are not avaulable form Yamaha, and there are no known equivalents.
Best bet is to get a wrecked bike.
Dec 27, 2009 | 1982 Yamaha XZ 550
I have had a 1982 280zx since jan. of 2009 the
Are you over tightening the belt? If I remember correctly, you should have 1/4" belt deflection after you tighten it.
Check the factory service manual: http://www.xenons130.com/reference.html
Hope this helps!
Todd in Idaho
'69 510
'83 280ZXT
'91 300ZXTT
Nov 03, 2009 | 1983 Nissan 280ZX
When driving to work it stalled and would not start back up it has no fire going into the distributor what could be causing this
coil,or timing belt does the engine sound slightly different when cranking it,if so the belt for sure rmove your cover check the belt even if the belt is still there check the teeth to make sure theyre not falling off somtimes this can happen when belt is rotten.this is assuming your car has timing belt not chain
Oct 19, 2009 | 1994 Dodge Colt
Tappet settings
for that application best to go to Chilton hand book to find. O'reillys Auto parts and Autozone can look it up for you and give you the specifications by phone.
May 27, 2008 | Mitsubishi Colt Cars & Trucks
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
131 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
