I used 4 diferent universal remote control for the Kogan hd32 tv without succes ,can you explain some one which brand or remote control is working with this tv?thank you
SOURCE: NEED THE CODE FOR MY UNIVERSAL REMOTE ACCESS 4 ALL FOR ONE
004
009
014
023 024 025 026 027
030 032 033 034 035
036 037 038 039 040
SOURCE: JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn
on the device you want to program into your remote, for example if you
are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There
are over 200 possible combinations for TV and DVD codes. The most
common codes are tried first but you may still need to press the Fast
Forward or Rewind buttons over 200 times to find the correct code for
your device.
If you reach the end of the list of codes, the
entire remote flashes twice and returns to normal operation. You can
exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
The lights for each device button light up and the light for the device button you selected remains on.
The device button blinks three times then turns off.
Did the device turn off?
Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
___________
The mode button blinks twice.
The
remote control tests each code in its library. The mode button blinks
once each time the remote transmits a new code. When the last code is
reached, the mode button blinks twice.
Did the device power on again?
Yes: Press Select to assign the code in your remote control.
No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
One of those three should work for you.
Hope that helps.
SOURCE: I need the centrex TV
Universal remote, in real sense, does not work universally with all makes and models. There is a limit to these. When they were introduced, there were 3 digit codes, then 4 , 5 and now there are few remotes with 6 codes. So, the database keep on increasing. If the code is not listed under the remote guide for your TV, this means that this remote cannot be used for your TV. You need to buy a remote which is compatible with your remote.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: my tv brand is d and I NEED THE CODE FOR A RCA universal remote
D tv..?? Pick your tv from the list on page 19 there is 4 tv's in the D's.....This is a Link for all the urc remotes 3605-9960 manual.. Save to your computer...Turn on your device and press the device button light blinks twice let go and push in code press power...
i puched in 1086 on my tivo remote and it turns my kogan tvlcd on aff as well as volume..
