Question about Mintek DVA-8700 System
We need the code so we can hook up the Sanyo TV to the satellite.
  • dlkundrat Jun 28, 2009
    Thank you for providing the code so promptly. We looked for the code for our hughes tivo box remote but were unable to find it. Does it cost another $9.99 to get it?
  • 508 Answers
10154-10088-10159-20047 good luck to you!!!!
Posted on Jun 28, 2009
    Brigadier General:
  • 3,917 Answers
the code is 0463
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com
or
http://www.sanyotv.com/RMT-U200%20(E)%200068A-.pdf
Thanks for contacting Fixya.
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Will my sanyo hdtv hook up to my toshiba satellite c655
If your TV has a VGA computer input connector, the you can connect a VGA cable from the TV to the video port on the Toshiba laptop.
Jan 27, 2013 | Toshiba Satellite C655-S5068 Notebook
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
I am trying to hook my tv up....what settings do I need to watch direct tv???
If you have a Sanyo TV with out audio/video connections, you will be using an RF connection cord between your TV and the satellite receiver. You will operate your TV on channel 3 or 4, match this with the channel 3 or 4 on the receiver box.If your TV has audio/video input connections, you will need to purchase rca connectors. They will have a red connection for right audio, white connection for left audio, and yellow is your video connection. The color codes will be on the input connections on the TV and the satellite receiver as well. You will than program the TV to input one or two, of the TV to receive the signal from the receiver. Use the satellite remote to control channels on the receiver box. When you are through watching TV, be sure to shut off your TV as well. Thanks for asking and show a few hands of support!
Feb 19, 2011 | Sansui Televison & Video
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
Sanyo VCR
get a 2 A/V cords (yellow, white, and red plugs). Plug between the Satellites "video out" jacks and the VCR's "input" jacks. Connect the second cords between the VCR's "video out" jacks and the TV's "video in" jacks. Make sure the VCR is set to the input that you plugged the satellite cords into and make sure the TV is set to the input that you plugged the VCR's cords into.
And then you're done. To record, set satellite to channel desired, set VCR to record on the video input (instead of a channel number) and you're good to go.
Sep 08, 2008 | Sanyo VWM-800 VHS VCR
Hooking up digital satellite system to sanyo 27'
if you can't operate the receiver from the front then there is something wrong with it. you need to get it repaired or replaced.
May 05, 2008 | Sanyo DS27510 27" TV
Need tv code for remote control
¿Porque siempre preguntan por el codigo para el control pero nunca ponen el nombre del control y el modelo ?
Mar 17, 2008 | Sanyo DS19310 19" TV
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
44 people viewed this question
Top Mintek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mintek Audio Player and Recorder Expert? Answer questions, earn points and help others
