Question about Dell Latitude D600 Notebook
Won't see clear image in display - Dell Latitude D600 Notebook
  • Dell Master
  • 32,281 Answers
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 29, 2009
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
What can I do to get my Manhattan 150095 PC TV Converter to display clear images on the TV or projector?
Most likely because its an analog converter and your injecting a digital image into it. Most all cable companies do not produce an analog signal so its displaying a diluted output.
Jun 08, 2014 | Manhattan Toy Manhattan Products PC to TV...
The display is black and won't show images or camera info
Sound like a display wrong, I suggest visit your photo techinican.
Jul 18, 2012 | Sony Alpha DSLR-A100 Digital Camera
I get many lines over my image i dont get picture clear i dont know whether it's the display mistake or lens' problem
If the lines you get are very sharp and clearly defined (which they most likely are) the problem is not with the lens. since the lens itself is very far from the focal point, any irregularity in/on it will only act to discretely modify the image in aspects such as brightness and overall clarity. therefore I think that the problem is with the image sensor or the display. assuming thus,
You can confirm which part is to blame by way of a simple test: while in normal view mode, zoom. If the lines become thicker, the problem is with the sensor. if they don't, the problem is with the display.
You can also take a picture with the cam and see if the lines are still visible when viewed on a computer. If they are, problem is with the sensor. otherwise the problem is with the display.
Whatever the case might be, you won't be able to repair it yourself, you'll have to take it to a professional camera repairman. If its warranty/guarantee still hasn't expired, take it back to the shop you purchased it from. They will help you.
I hope you manage to resolve your problem. good luck!
Sep 05, 2011 | Samsung S760 Digital Camera
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
The display screen will not clear on my FinePix A900
Go to the web site and see if they have a chat with a tech mabey this will help.
Dec 30, 2008 | Fuji FinePix A900 Digital Camera
Display not clear
If you know to remove the panel you can remove it and clean the dust on the display or else take your mobile to any service shop,they will do it for you!..Thank you..
Jul 19, 2008 | Nokia 6600
Error code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Workcentre Pro 215
This should resolve that fault code
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Dell Latitude D600 Notebook Logo
188 people viewed this question
Alun Cox
