Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Water leaking into refrigerator compartment from freezer
    Problem Solver:
  • 15 Answers
There is a drain tube that allows water to drain from the freezer during the defrost cycle, it gets plugged from time to time, you will need to find and clean out this tube, it is sometimes of the back of the fridge.
Posted on Jun 28, 2009
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have water collecting on the iside of the refrigerator compartment. It is leaking through the air vent openings from the freezer compartment.
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water is leaking from freezer into lower compartment of kenmore
If you think it is the ice maker then shut down the water supply and see if the leak stops. Most likely though it is probably a blocked defrost drain.
Apr 09, 2009 | Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
317 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
