Need to know how to remove oven Model #SCA1000DWW03 from mounting above stove in order to take to repair service - unable to locate installation manual
The removal instructions are on page 34 of the service manual, and we
have uploaded it to our
site here to help you.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Need to know how to remove Advantium 120
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
