Question about APC Smart-UPS 1400RMINET (SU1400RMINET) UPS System
Internal fan keeps running until I turn machine off and push test. All green lights now operates with the fan off_for awhile. Need I be of any concern?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Your UPS needs calibration. you need to do some UPS calibration here. but my concern here is anyone in your area knows how to do APC UPS manufaturing calibration?
Thanks!
Posted on Aug 14, 2009
How long after burner is on should fan come on ?burner going out fan not coming on how to test fan or thermastat?
Your furnace has a fan delay relay that should turn the indoor fan on once the temperature gets up to about 150 degrees near the fan. The delay relay closes and energizes the fan circuit and opens once the thermostat is satisfied and the main gas valve turns the gas off. The delay relay keeps the indoor fan running for until the air temperature gets back down to around 100 degrees. If the fan delay relay stops working it will need to be replaced. Temporarily you can turn the fan to on on the thermostat and the heat should operate normally until the relay can be changed. The indoor fan will just run continuously. At least you will have heat.
Hope this helps
Feb 12, 2015 | Heating & Cooling
"I tried to install another internal HDD + another 256 RAM (both of them are used) to my computer, operating XP with an ASUS P5P800S motherboard. When I ran the system, the new device was found by the sys....
The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Sep 26, 2014 | ASUS P5p800s Motherboard Intel 848p Lga...
I have a 1997 acura cl 3.0 everytime i turn off my car the cooling fan stays on for quite awhile
The cooling fan is controlled by a heat sensor and operates independently of the motor. When you turn off your Acura, the cooling fan continues to run until the sensor determines the tempurature has decreased enough to turn off the fan
Dec 24, 2012 | 1998 Acura CL
My Sole f83 will not start. initially Fans run, can raise/lower. will act noemal until motor should run/doesn't. then raise/lower function stops. If I try to use speed buttons LS light shows. moto
LUBE or wax the deck belt, this happen because you do not have schedule maintenance according with the owner manual. The machine shut down for autoprotection in electronic system Do it NOW.
2) LUBe the rollers bearint too with WD-40 only for rollers
3) Test the drive belt motor, for worn or cracking belt, replace or adjust it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for troubelshooting help.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 15, 2012 | NRS Sole F83 Treadmill
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
HE2 Kenmore Washer stuck on F01 error message and Add Garment light on. Any trouble shooting suggestions?
The F01 error is a communication error and most likely the cause is a bad central control board. You tried to unplug the power and the machine still will not start so next I'd recommend trying to run a diagnostic cycle to verify the operation of the central control.In the image below are the instructions to enter and run the diagnostic routine. If the process is done successfully all of the LED light will come on for 5 seconds then display the last error. Push the same button until the error code ends and all the lights come on again for 5 seconds then the test will start.
If the test runs through okay then the central control unit is most likely okay. If it fails to enter diagnostic then the control has failed and needs to be replaced.
The last thing to try is to check the connections on the control. A loose connector might cause this problem
To see how the control unit  looks please check out this link.
http://media.fotki.com/1_p,wkdgrwgdsbqrsbbxgtqsskgwtqkq,vi/gfbtbqbdfxgdwrwktgr/1/1303472/5961857/image59835img-or.jpg
Resolution: Error code F-01 can be caused by a power surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
To clear and restart the control follow the below listed steps:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit into the wall outlet.
  3. Wait for another 30 seconds to allow the control to recognize all components.
  4. Press the Pause, Cancel or Stop button twice to clear the display.
  5. To test operation of the washer,select Drain & Spin cycle, then press and hold the start button until the machine starts.
If the cycle does not start, there may be an internal component failure that requires service by a professional technician.
Note: General information for resolution is based on information provided in question. Please contact a repair technician if problem persist. Call Sears Repair Service 1-800-469-4663
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Kenmore HE2 Plus Front Load Washer
The fan on the condensing unit isnt working it works for awhile and then shuts off,then the compressor starts to work by itself really hard and the whole condenser heats up really fast so I turn off the...
Does the fan turn freely or is it hard to turn by hand? If it is hard to turn the fan motor may need to be replaced. If it isn't hard to turn then check the fan capacitor. You can test it with a multimeter or take it to a heating and air supply and get them to test it. A fan will run with a bad capacitor if you get it started but it will not start with one. Let me know what you find.
Aug 14, 2010 | Goodman CLT36AER36 Air Conditioner
I have a kenmore Elite Ultra Wash Dishwasher that won't run. The lights for the various wash and dry options come on, but when I push the start button, it flashes green three times and then goes off.
Sounds like a safety - lock is operating.
Close and press start button - keep button derpressed untill machine actually starts - maybe 8 seconds or so.
If this does not do it, unplug for 24 hours then try again.
Aug 04, 2009 | Dishwashers
HP dc5000 won't start. Green light on front is dim and flashing.
Hold down the power button until the machine completely turns off. Then turn the machine back on and let me know what happens.
May 26, 2009 | HP Compaq dc5000 Small Form Factor PC...
Flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Jan 07, 2008 | Heating & Cooling
APC Smart-UPS 1400RMINET (SU1400RMINET) UPS System Logo
318 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
