Question about Belkin (F5D7230-4) Router (587009)
Have wireless signal but no IP
At home I have wireless , I have excellent signal strength , but no internet access , I am fed up visiting internet tools connections lan settings , router is belkin g router , laptop is dell
  • 244 Answers
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Posted on Jun 28, 2009
Windows vista laptop failing to connect to some wifi networks including my home one.
Open Network and Sharing Center, Manage Wireless Networks, Remove your Home one. Exit Network and Sharing Center. reboot machine, Try to reconnect to your home one. If that fails, Release and renew IP : http://www.cs.cmu.edu/~help/networking/IP_renew.html
Dec 11, 2012 | HP Computers & Internet
DIR-815 Signal strength excellent but no internet
Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
Dec 21, 2017 | ASI Computers & Internet
My router is not gettting connected with laptop. Its hsowing lmited connectivity problem eventhough the signal strength is excellent.
Sometimes the router does not issue an IP address to the laptop and you get this error message.
Right click on the wireless icon on the Task Bar and click on Repair. The router will issue a new IP address to your laptop and you will be able to get Internet connection.
Dec 09, 2010 | D-Link Wireless N 150 Home Router 4Port...
Connects and drops when using wpa will not stay connected has great signal
Please check for the wireless signal strength of the wireless router.
Try to access the internet in an area where the signal is excellent.
Oct 30, 2010 | OTC ACR201-G (00CSPP000122) 802.11b/g...
When i switch on my ADSL modem which is connected thro the dlink wireless router,my laptop shows"No internet access" in the task bar,but the signal zebra-band is visible-excellent signal...
Check your ip settings in your pc and make sure they are set to get dynamically. Also check under wireless lan settings that you have dynamic ip turned on.
Otherwise you will manually have to set your computer ip address to the range set in the router/modem
Oct 23, 2010 | D-Link Computers & Internet
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
WRT54GS wireless router problem
It's possible that the wireless network is secured. you can access the router setup page to check if there is a security enabled. You can follow the steps on this link.
May 06, 2008 | Linksys Wireless-G WRT54GS Router...
Enuwi-g2 problems
What operating system are you using, Win XP?
Go to the control panel - look at Network Connection, click on properties on your USB adapter, click on Internet Protocol (TCP/IP), then Properties, make sure Obtain an IP address automatically is selected.
Also make sure your USB adapter settings (SSID, WEP/WAP etc) matches your Access Point settings.
Mar 04, 2008 | Encore Wireless Ethernet Network Adapter
Wireless internet
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Feb 09, 2008 | 2wire (1000-400108-001) Router
Belkin (F5D7230-4) Router (587009) Logo
323 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
