Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
The blades on my Badger 1 insinkerator don't move. The motor hums when turned on. The reset button stays out when pushed.
  • 65 Answers
You will need to free the blades by inserting the food disposal hex key or a 1/4 Allen Wrench into the very bottom of the disposal in the center. After inserting the wrench you need to turn it all the way in both directions to free what has the blades held up. It may be hard to turn but afterwards pull the debris out from inside the disposal. Hit the reset button and it will work. Do not keep turning it on until you free the blade and then reset.
Posted on Jul 22, 2009
  • Rydo Sep 23, 2010
    This worked a treat for me. I have the Badger 1. The machine wouldn't turn...just gave a hum. I ran the machine for about 5sec with the hum and the reset popped. I hit the red button to reset, used a hex key as per the above instructions, felt the friction disappear. Fixed!!...or is that fixya? :)
My insinkerator is humming and not working. I bought the wrench and keep playing with it but it it stuck. My son insists that the engine is seized but I feel if it were seized it would not turn on at all....
Your Badger 5 spins the blades counter clockwise. If you want to dislodge an item stuck in their, you have to spin the blades clockwise. I use the handle end of my plunger to do this. If it turns free with the handle, it should work when you turn it back on. If you don't hear it hum any more their is a little red reset button on the bottom of the motor housing you must press to reset it.
Sep 03, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal will not spin. It has a humming sound when I turn it on but it will not work.
first reach under the disposal and there is a reset button under there push that and see if it works, if not then there is a wrench that came with your disposal you need take that and put it in the slot under the disposal and give it a turn to loosen the blades up, then hit the reset button again. If that doesn't work then sadly the motor went and will need to replace it.
Mar 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator hums when turned on, but does not start. Blades turn freely when hex key is used on the bottom
Look for the reset button under the bottom. This may get you going again. If not, you may need to replace the unit. Sorry.
Best regards, --W/D--
Jan 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 garbage disposal just hums. There is no jam in the blades; they move freely in both directions. I've pressed the reset button and allowed the cold water to run. I've been working on it for 2...
When the motor goes bad, it begins to slow down until it stops.
That can happen suddenly, and now each time it hums, the motor is overheating and will never come back to life.
I wrote ez replacement step from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jan 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming noise when turn on, but blade/motor not moving. Tried reset button and turn the motor with allen wrench. What else can I do?
its stuck, is it still under warranty. either the motor is bad or something is jammed in there. you need to turn the blades by hand or allen , if nothing, then the motor is somehow bad, need to replace.
Mar 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator
The capacitor is probably bad, that's what makes it start to rotate. It's under the metal case on the side of the motor. Pull it off and take it to a motor to to replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,762 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
