Question about Karcher K2.26 Electric Power Washer
I need help re-attaching my choke lever for a Excell VR2522 Pressure Wasker. The choke lever has become un-attached and I need a visual presentation of what it should be attached to.
  • gpwolcott Jun 28, 2009
    I need help re-attaching my choke lever for a Excell VR2522 Pressure Wasker. The choke lever has become un-attached and I need a visual presentation of what it should be attached to. The user manaual does not mention anything about repairing/re-attaching the choke lever.
  • 240 Answers
Yourpressurewasher.com/vr2522_2.html ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump these links would be much useful to u
Posted on Jun 28, 2009
    Sergeant:
  • 326 Answers
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps,
    Brigadier General:
  • 3,917 Answers
Please find the details in the user manual in the bellow link:
http://www.excellpressurewasher.com/documents/pdf/a13607-e.pdf
Thanks for contacting Fixya
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
Have an Excell 2500, VR2522...... Pull cord broke and now i think the spring is broke; where can I get a new spring and directions to reassemble the pull start?
That pressure washer uses a Honda 5.5 hp overhead cam engine
You need to get the model number of the Honda Engine and then Click Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Jun 23, 2011 | Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Choke is not hooked up to anything. What does the choke hook up to on a troy built tiller?
The choke (butterfly valve inside the carburetor) is attached to a lever on the side of the carburetor. This lever opens and closes the butterfly valve. Attach the choke cable to this lever.
Apr 29, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Karcher K2.26 Electric Power Washer Logo
89 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
