Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
My blue color is out of alignment. I tried
My blue color is out of alignment. I tried aligning it manually but it doens't move. I tried the magic focus and that doesn't fix the problem. How do I get the blue back in alignment? It swoops down on the picture,
  • 2,071 Answers
Just try the reset first by unplugging the cord from the wall for 4 hours in oder to drained the current stored inside in the IC memory so it will erase and return to its original setting.
Good luck:
Regards:
VOTIT
Don;t forget to rate:
Posted on Jul 07, 2009
    Problem Solver:
  • 15 Answers
There are integrated ic's that control the convergence circuit, it generally requires qualified service personnel to repair this.
Posted on Jun 28, 2009
The color red, yellow and blue on my canon ir c5185i are not togeather. How do you adjust them to be one color?
Follow the instructions to align the colours try automatic align first, if no improvement select manual alignment.
Dec 05, 2013 | Canon Office Equipment & Supplies
Magic focus --blue and yellow sag in the upper left area of the screen
This is a problem with the convergence circuit. If you can solder, you can repair this yourself. First try and resolder the pins on the existing convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs.
Dan
Mar 22, 2008 | Hitachi 53FDX20B 53" Rear Projection...
In the middle of my tv at the bottom the are green blue and red colors what can that be
The three CRTs (green, red and blue) are out of alignment in that location or the convergence circuit has failed altogether. Look in the users menu to see if they have a "converge or convergence" option to do a simple alignment.
If not, download the service manual and follow the instructions on how to do the alignment.
Note: if you can access from the user's menu, but the colors do not move when you try to adjust, then the convergence circuit has failed and will need to be repaired.
Mar 08, 2011 | RCA R52WH76 Television
Need to align colors in convence option can move them just dont know where to
Convergence adjustments are made by aligning the Blue and Red to the Green... Make sense? Green does not move, it is the fixed point by which the other 2 colors are to be aligned to.
Mar 15, 2010 | Philips Televison & Video
Colors are out of alignment
There is an alignment mode that you can get to. You must take off the back cover and look for the alignment switch I suggest that a tecnician do this because he has the propper tools and knowledge. If just an allignment is all it needs it should not cost that much. You have to try not to move this type of tv around because it is very sensitive and the slightest bumb can send it out of wach.
Nov 17, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Color Alignment
get a shop manual,it tells how to do the whole convergence process and how to store it to the rom memory to save it.
Mar 15, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
194 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
