Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
A
Anonymous Posted on Jul 04, 2014
How to replace main control board - Maytag MLE2000 Front Load Stacked Washer / Dryer
LG Dryer DLEX4000 - will not turn on.
If you have replaced the thermal fuse, main control board, control board behind the start button, and the high limit, and the dryer still will not turn on, then there may be an issue with the motor or the door switch.
First, check the door switch to make sure it is functioning properly. If the door switch is faulty, the dryer will not turn on.
If the door switch is working properly, then you may need to check the motor. The motor could be faulty or there could be an issue with the motor relay on the main control board.
You may want to consider consulting with a professional technician who can perform diagnostic tests and determine the root cause of the issue.
Nov 22, 2022 • Dryers
Hi, my defy side by side fridge freezer F740 is giving me a E20 error code? Please give me some guidance.
I BELIEVE ITS A CONTROL BOARD ERROR CODE
ERROR CODE DEFINITION:Communication error between the main control board module - and display control module.
WHAT TO FIX/CHECK/REPLACE: Remove power to the refrigerator and reconnect any loose or non-secure connections on the wire harness for the main control board module and the display control module.
-Remove and Replace the wire harness if faulty.
-Inspect the main control board module and the display control module if faulty.
PARTS THAT MAY NEED TO BE REPAIRED OR REPLACED: Main Control Board Module -
SEE THE MANUAL ATTACHED
1helpful
Replacing a DC controller board
When replacing DC/main PWB or engine board, be sure to remove the EEPROM from DC, main PWB or engine board that has been removed and then re-attach it to the new DC/main PWB or Engine PWB, cheers
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
Electrolux washer displaying error code E5E
Communication problem. Check the wiring between the Main
Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
1helpful
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
E11 code on electrolux dishwasher
You are experiencing a drain valve issue - Main Control Board timed out before receiving status of drain valve. Check wiring between Main Control Board and drain valve. If correct, replace drain valve. If error still exist, replace Main Control Board.
1helpful
E5F CODE ON WASHER
Communicationproblem. Check the wiring between the MainControl Board and the Speed Control Board. Wiring bad, correct wiringproblem. Wiring good, replace the Main Control Board. If the problem is notcorrected, replace the Speed Control Board.
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
4helpful
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
