Question about Homelite Mighty Lite Lawn Trimmer
MightyLite is a Real POS. Brand new and only runs on half choke
I have read this forum, and I agree with all the tech tips for older trimmers. But why would Homelite build a trimmer that won't run right out of the box, and use special jet screws so that normal homeowners can't adjust them? I should have taken this POS back the day I got it, and I refuse to take a $70 new trimmer in for service and pay again. If I can't get it to run, I am just going to toss it in the garbage where it belongs. It will start on full choke, try to run on half choke for a few minutes and then die. It will not run on the Run setting. I will never buy a Homelite product again. Any help with this POS is appreciated.
  • 155 Answers
Agreed all these cheap trimmers are built at a price the only way to tune them is to take it to the dealer, The special tool costs nearly as much as the machine.
So most machines under 100 dollars are throw away and replace its bs but everything is ending up the same.
Posted on Jul 26, 2009
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
My Homelite grass trimmer idles fine but when I open the throttle it stalls. How do I fix this?
Its sounds like it is running rich. Adjust your high speed adjustment screw. If the unit is older think about buying a carb rebuild kit, they run about $12.00 at your local fix it shop and if you are not in a hurry online for about $8.00 give or take S/H.
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
I need a manual for a Homelite Mightylite 17 inch Curved Gas Trimmer with EZ wind Bump Feed UT 21907 Ser #642287
Go to homelite.com then click on service and support, then click order parts then click launch homelite parts catalog, Agree to terms then click continue under model no type in mightylite then find you trimmer in list.
Apr 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lawn trimmer vt26
Go to www.homelite.com then in the red area up top click on order parts, then click launch parts catalog, then scroll down and click agree and then you will need your model # then you will have a list of breakdowns that you can look at for your trimmer
Oct 26, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
364 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
