Question about Maytag Washing Machines
I have a Maytag Neptune front loader. It was running and someone pushed the pause/start button to add clothes. I have unplugged it, turned it off and I can't get it to work. Any suggestions?
    Brigadier General:
  • 3,917 Answers
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Call an engineer or research Washerhelp's forum archive
Thanks for contacting Fixya
Posted on Jun 28, 2009
Wont start. I soaked a shower curtain in bleach, ran the machine to add water and then hit pause to allow the fabric to soak in the bleach before washing. I pushed the pause buttonn to continue thewash...
I would unplug the washer to reset it. if you have already hit the power button to turn the unit off and it failed to respond. Newer washer machines are like computers, and smart phones these days. you have to reboot them because they do sometimes lock up. Pull the cord for about 5 minutes and see if that resolves your issue.
Dec 03, 2013 | Maytag MAH6500 Neptune Front Loading...
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag front louder door won't lock or even stay shut?
it sounds like you have broken the switch which keeps the door latched when not in use as well as locks when the washer is started. These latches often fail when someone forces the door open to add more clothes without pushing the pause button AND waiting until the "locked" light goes off. Older children and teens and yes, uninformed men, are apt to do this. You will need a repair person.
Jun 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
