Question about Bose Companion® 5 2.1 Speakers
Does the speaker have a fuse - Bose Companion® 5 2.1 Speakers
  • 2 more comments
  • dcostavelan Jun 29, 2009
    i purchared the Bose companion 5 2.1 speakers it has a rated voltage of 120 V and i connected the system to a 220V power supply socket. an orange colour light blipped on the sound control nob and then went off.does the speaker have a fuse inside.how should i fix this problem.also how do i connect the 120V speakers to a 220V power supply Socket
  • Mir Khan Jun 16, 2013
    @norwood54 your solution "Probably not, you may have fried the speaker." is just a coment so it shouldn't be presented as a solution so think before you ink.
    I was looking for a solution for the same issue. Power surge fried surge protector and the bose. Since it was way pass the warranty, I disassambled it. It has a Varient fuse rating 220-240 ->(arrow) T1.60A L,250A Next line 100/120v -> T3.15A L,250v. Unable to find fuse if someone has a link or information, it will be highly appriciated. Thx in advance
    Correction 220-240 -> T1.60A l,250 v (not A)
    Problem Solver:
  • 15 Answers
Posted on Jun 28, 2009
What is the voltage and wattage of the Cerwin Vega E-715 speaker fuse?
Speaker fuses are rated in Amps. If you cant find the specs on your speaker via google, (I couldn't find anything on the fuse.) start with a 2 Amp 'slow-blow' fuse. That should work at low to medium volumes. If you find it blows at low volumes, move up to a 4 or 5 Amp fuse. E-715 is a big speaker, (handles 400W!) so starting at 2 amps should be pretty safe.
Feb 11, 2016 | Cerwin Vega Audio Players & Recorders
I want to check my radio speaker fuse on my 2003
You have a fuse for the factory amplifier. It will be lo ated in the fuse panel.
A thumbs up would be greatly appreciated want-check-radio-speaker-fuse-2003-jjq1gbgvbnuqnoqvaolrtxpp-1-0.jpg
Sep 19, 2014 | 2003 Chevrolet Monte Carlo
E315 cerwin vegas speakers and one keeps blowing a fuse when I turn it up to the normal volume I play them.Can I use a bigger fuse or is it the speaker?About a yr old rarely used until the last few mo
Try playing the speakers at a friends house or something to see if you blow their fuse. If you don't then you know for sure that you need a bigger fuse, but if you do then it's the speaker.
Jun 03, 2013 | Audio Players & Recorders
Speaker fuse
Most likely there is something wrong with your speaker. A bigger fuse is not going to help, and could cause more damage.
I cant get any sound from my speakers only the subwoofer will work
Klipsch, usually fuse the speakers. look at the back of your speaker to see if there is a fuse holder, if not, it may be internal and if there is a panel you can take off, do that and look inside for a fuse and check it with a volt/ohm meter if its blown replace it with same value fuse. Aother way you can check to see if the speakers still work is to take a 9 volt battery and touch the terminals of the battery to the terminals of the speaker, if you hear a clicking sound or better yet can see the speaker move in or out the the speaker is good and the problem is elsewhere in your system. if both speakers don't work I would first suspect the fuse in the speakers. you could also try hooking up different speakers to your amp and see if those work, one last thing, plug in some headphones, if they work you will know that at least that part of your amp works.
Mar 13, 2011 | Klipsch KL-7502-THX Speaker System
Logitech z5500 speakers no power
certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Mar 29, 2010 | Logitech Z-5500 5.1 Digital Speaker System...
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Cut harness from stereo in 1990 corolla dx sedan
did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Dec 19, 2008 | 1990 Toyota Corolla
Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Oct 08, 2008 | Bose 151 Main / Stereo Speaker
Bose Companion® 5 2.1 Speakers Logo
144 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
