Question about HP Pavilion 524w (DB280AR#ABA) PC Desktop
I recently moved and when I hooked up my computer, the tower will not power on. What could be causing this
    Problem Solver:
  • 15 Answers
There is a master power switch switch on the back of some computers, just under where the power cable plugs in.
Posted on Jun 28, 2009
My pc was taken apart so I could move. When I hooked it back up the monitor comes on for a couple seconds and says that my pc is in analog power saving mode. The power light on the tower just blinks c
It might be in a corrupted hybernation mode.
Try turning the computer off by pushing the power button for 10 seconds and then do not choose resume but the other option.
Nov 08, 2013 | HP Pavilion Computers & Internet
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
I have a zx4351, touch sreen wireless gateway desk top computer , i had cable co. today to hook it and now my screen does not turn on and has no power going to it what is it?
Your desktop tower/cpu tower has to be turned on to give those hardware power. If you can't turn on your computer then that means you have an internal problem with your motherboard etc. If everything else powers up except for the screen/monitor your video is dead. Find someone you know that has an extra monitor and hook it up to your tower, if it works then it's not your video but the monitor instead.
Dec 01, 2012 | Gateway Computers & Internet
Our Computer tower is not wanting to turn on. Is there any way something could have been hit on the back or a button pushed in moving it that would cause it to not turn on?
Hello.
some towers have a switch on back for the power supply power. If you have one, try to switch it back on. If you don't have one and the computer doesn't make any noise, it's likely a power supply issue.
Hope it helps.
Feb 08, 2011 | Computers & Internet
I recently moved, my computer tower was working fine before i moved it, and now it doesn't even turn on. i've tried different plugs and when i looked inside it, a green light is on, so it is apparently...
Do the fans inside the case spin?
If so, then the computer is getting power.
If you have an older computer, with a Pentium 2 or Pentium 3 CPU, it's possible that the "slot-mount" CPU has been dislodged from its "slot" socket. Turn the computer off. Disconnect the AC power.
Make sure that the CPU is properly "seated" into its socket.
Oct 04, 2010 | Computers & Internet
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
Hp tower powers up but won't turn on. It also has a consistant beep.
Sounds like a hardware problem. Has the computer been moved recently? Check that all cards and cables are securely connected.
Here's a list of beep codes
Jul 02, 2008 | Computers & Internet
Signal Cable Problem
Check the monitor plug that goes to the computer for bent pins. or try another monitor/or cable .
Jan 12, 2008 | Computers & Internet
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
HP Pavilion 524w (DB280AR#ABA) PC Desktop Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
