Question about Canon Pixma iP6000D InkJet Photo Printer
The waste ink absorber for canon i9900. please help
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer (pull the mains plug) ,switch it on
- ready to print
Posted on Aug 09, 2012
    Sergeant:
  • 361 Answers
You can change ink absorber. if not ,you can change this boxe,s absorber sponge in same size. it workes is absorber wastage ink of printer. thank (nepal)
Posted on Jun 28, 2009
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
  • 1550 Answers
SOURCE: Reset Waste INk Canon MX318
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 16, 2008
  • 32 Answers
SOURCE: indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
Posted on May 28, 2009
pineworks
  • 4041 Answers
SOURCE: My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
pineworks
  • 4041 Answers
SOURCE: waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
Testimonial: "Very best solution!!!! Thank you very much !!! Good luck!"
How do I change the ink waste absorber on a canon i9900
Turn the printer off.
Disconnect the AC power cord.
Lift the lid to expose the print-head mechanism.
Look where the ink-cartridges are "parked".
The ink-absorber is below those ink-cartridges.
Close the lid.
Reconnect the AC power cord.
Turn the printer on.
Lift the lid, and wait until the print-head slides away from that "park" position.
Without turning the printer off, disconnect the AC power-cord.
Now, you have access to the absorber.
Change the absorber.
Oct 21, 2010 | Office Equipment & Supplies
Can you tell me how to empty the waste ink tank on a Canon i990 inkjet printer
There is no ink tank, it's a set of fitted absorbent pads underneath the entire print engine. You need a shop to replace them since you need the service mode to reset the counter and clear the error.
Aug 10, 2009 | Canon i9900 InkJet Photo Printer
Waste ink absorber almost full
I suggest that you will go to your service center if you don't know how to disassemble the unit..it need to be disassemble in order to clean the absorber and replace a new one..
May 17, 2009 | Canon i9900 InkJet Photo Printer
Indicates waste ink absorber is almost full on cannon i9900 print
May 16, 2009 | Canon i9900 InkJet Photo Printer
Canon i9900 printer error "waste ink counter is almost full"
You can try I think it is, but also try cleaning the heads that also will gave the same code
Canon i9900 waste tank reset
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Apr 02, 2009 | Canon i9900 InkJet Photo Printer
Waste ink absorber is full
Hello there yes you can try
Or try
7) Print away!
Nov 19, 2008 | Canon i9900 InkJet Photo Printer
Canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Aug 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp 130 printer waste ink
hi
am AJAY FROM INDIA
off the printer and open upside cover,see 'the waste ink absorber if there any spunge pull that
and empty the waste ink from sponge or waste ink absorber
ok
again cloused the upside cover
ok
Jan 03, 2008 | Office Equipment & Supplies
Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Dec 22, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
258 people viewed this question
old marine
old marine
