Question about Sony Ericsson W380i Cellular Phone
My LCD screen no longer works.
Nothing appears on the LCD screen and it just happened
  • 544 Answers
HI,
it seems that yor screen is dislocated inside.
they are chance this will happen specially if you accidentally drop or hit the unit.
bring your mobile to a service center and let them fix it for you.
thanks,
Posted on Jun 28, 2009
Why does the display appear and disappear after 2 seconds of being plugged in, and I cannot get it to work?
This could be a setting for a timeout of the LCD screen.
It may be a defective product if you cannot print or send test prints.
May 25, 2014 | Staples Office Equipment & Supplies
E1235 - nothing appearing on screen/can't photo view
Ok, I just solved this issue. I have had the issue for a while and called GE and they told me they would give me a discount replacement at $125, when new it is less then $100. SO GE ITS NOT HAPPENING!!! Well I decided to fix it my self.
1st: Take out all the screws (7 total) one is hidden under the av out cover. Make sure u mark all the longer screw heads and location with a marker so you know where they go. There were only to sizes so if you mark the longer ones you should be ok.
2nd slowly pull the back of the camera back (BUT BE CAREFULL, do not pull to far there are wires from the LCD and buttons to the camera.) Now there is a little tab on the main board holding the wires from the LCD to the camera. Flip it up and remove the LCD wires. After you do that push the LCD wires back in and flip the tab back down. Be careful not to damage wires or tab. Put case back together, put screws in where they go, and wallah. Your camera should work. If not try again, and make sure your properly putting wires in. If it doesn't work email me I will be making YouTube video for this soon. REMEMBER TRY AT YOUR OWN RISK!!! I AM NOT RESPONSABLE FOR ANY DAMAGE YOU CAUSE!!!
Apr 17, 2010 | General Electric GE E1235 Digital Camera
Nothing appears on the LCD for printer
This simply. You to come to remove front panel and look connectons in +5 V since if was the all problem, but did not work all ))
Mar 14, 2010 | Office Equipment & Supplies
Black screen
If the light stays on for longer than about 20 seconds, try moving the lid back and forth, try positioning it in every possible way. If you get an image, even for a second, you need a new LCD cable. If nothing happens, try to get your hands on an external monitor. Plug that bad boy in, if you get the image, you need either a new LCD cable or a new LCD screen. If still nothing happens, then you probably need a new motherboard.
Before you go buying a new MB/LCD/LCD cable, which can be rather costly, open up the back and make sure the RAM is seated properly, sometimes something can jar RAM sticks loose.
P.S. DON'T FORGET TO VOTE
Apr 15, 2009 | Acer Aspire 5050-3371 Notebook
Monitor has just stopped working
perhaps a repair shop. most electronic devices fail this way
Oct 06, 2017 | Hanns.G Corporation HX191DP LCD Monitor
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
Dec 23, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Harmony 890 Pro dropped.....everything looks fine but it no longer controls system
You will have to open the unit up and repair whatever broke.
When this has happened in the past to less complex remotes, I have found that usually the oscillator chip has broken off of the circuit board, but whatever it is will have to be resoldered back into its original position.
If you have never worked on electronics before, you will have to take it to a repair shop, send it to the manufacturer, have a knowledgeable friend repair it or buy a new one.
Aug 12, 2008 | Logitech Harmony 890 LCD Remote Control
Not optimum mode recommended mode 1024 x 768 60hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Sony Ericsson W380i Cellular Phone Logo
162 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
