Question about Kenmore Dryers
Is gas turned on with pilot light or electronic?
We have a Kenmore model 22000 gas dryer (stock 7207611W) which indicates it is natural gas, has been in house since we bought in 1976. How is flame started when heating starts. We need to turn off to tent house for termites but do not know how gas is shut off or turned back on. All these years and we never needed to know this.
  • 999 Answers
No pilot. Unplug the power to the unit and it cannot run/ignite. There is a shutoff on the valve behind the front panel if you want to turn off the gas supply without moving the dryer.
Posted on Jun 29, 2009
Dryer runs but does not heat on maytag model med6000xw1
If you have a newer model with electronic ignition, check igniter by the burner, or if a pilot light ignition, obviously re-light, but possibly the gas safety interlock switch is tripped by a weak pilot flame, which causes main gas valve to stay off. Best guess, igniter element has cracked, and is simple to replace, order online.
Oct 30, 2013 | Kenmore 62602 Electric Dryer
Hi more info. I posted wrong. my dryer is model 11079912990. ser # mj1607152. type ddot-nat-1206006, cv22. 120 volt, 60 hz. 22000 btu .27 inch wide kenmore gas dryer. The dryer would run for a few...
You could have a blown fuse because of a clogged vent or a bad thermistor. A thermistor is used by electronic controls to measure temp changes inside the dryer. If the sensor is open then the brain does not have a clue how hot the dryer is. So it shuts down. Repair clinic has an excellent thermistor replacement video.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2013 | Sears Kenmore 7.3 cu. ft. Gas Dryer Model...
Does it have a pilot light?
yes it is electronic called a pilot generator
Jun 14, 2012 | Kenmore Dryers
My dryer wont get hot . think the pilot is out . .. how do i relight the pilot
send the model number,you can't light the pilot anymore,they are electronic ignition now,is it gas or electric?find the model number around the opening where you put the clothes into dryer
May 08, 2010 | Kenmore Dryers
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
134 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
