Question about Dryers
I have a Hotpoint WDM73 washer dryer, during a spin cycle the power cut out and it won't turn on again. Can you help please?
  • 82 Answers
On a hotpoint the moter is three faze so if it is turning the power off this means that the moter could be damged between the windings u can get the moters off ebay from about 55 pounds
Posted on Jun 28, 2009
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Hi!
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Regards,
Bogdan
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
My hotpoint ultima is not heating, the drum spins. could you advise what the problem is
For most Hotpoint (and other named) models there is a common problem often indicated by 'F08' which decodes as 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 18, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hi, my hotpoint wdm73 washer dryer keeps tripping
Remove the top cover, and unplug the motor, and try again, if it still trips, then disconnect the heater element.
If it still trips, then I recommend you all an engineer.
Jan 25, 2010 | Hotpoint Dryers
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Jan 22, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
90 people viewed this question
Top Dryers Experts
