As my computer was hanging due to a leaking resistor, in my hurry, I rolled back my hard drive back to two years and and then reformatted it, can i get help how to recover my data, please
Sorry, no help for you after doing both a roll back and a reformat. This is what has driven professionals to a 3-2-1 backup solution.
3 backups - 2 onsite(two different parts of the house, business) - 1 off-site. Then you can restore from a backup. Otherwise, restore from optical disk or restore partition(if you didn't format it).
Good Luck.
SOURCE: Computer does not recognise Hard Drive
Hey guys. I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even
though it worked for several months then all of a sudden when I tried
to hook it up to another computer, it stopped working. It would
recognize the USB connection but you could not read the drive as it
would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But
what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or
something similar to that. For those that are wondering, yes, the hard
drive is a Western Digital Hard Drive. Western Digital Caviar to be
exact.
Solution: You need to open the cover to the hard drive and reconnect
the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily
come off if you accidentally knock over your hard drive or move it to
another location. The hard drive is held in place by screws on a
holder where there is room for the screws to slide if the screws are
not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it
works and it's really easy and quick to do. Took me 15 minutes.
SOURCE: Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
SOURCE: my external hard drive is corrupt, i want my data back.
Dear,
Data can be recover but the drive must be accessible by OS. As you write windows vista says drive is not accessible and that the disk structure is corrupted and unreadable.Do one thing try the same drive at another PC. If it run on that PC copy the data to that PC. Now format the drive and paste the same data back to your drive. But, if same thing happend then there are chances of fault in the driveand for this you shuld visit to the service cetre but, they are not responsible for the data.
Thanks & regards,
Rakesh Kumar
SOURCE: WD320GB hard drive not working
Are you using a double power USB cable, which normally comes with W/D hard drives?
Also if the light on hard drive blinks the drive is not getting enough power from the USB port.
All the best!
SOURCE: How to recover data from an undetected 500gb hard disk drive?
If the HDD is not detecting in the BIOS then It’s seems like to be a firmware issue on this particular series of HDD
for
Model: ST3500620AS
Firmware: SD15
Barracuda 7200.11 500GBytes
The one & ultimate way is to contact the nearest seagate center in your location to get the data back up & if your drive is under warranty then mostly it will be free of cost. (Not Sure about it)
