Question about Mitsubishi WS-55807 TV
How do I remotely change the channels on my MGA Model CS-1946 R TV?
I can only manually change the channels on my Model CS-1946 R MGA TV. There are no arrows on the remove to change the channel. How do I cange the channels by remote. Aso what does QV and Disp on the remote mean?
2 Suggested Answers
SOURCE:
  • 16 Answers
SOURCE: Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Posted on Jan 20, 2009
How do you get your tv to channel 3 without remote
It Depends on the model but most tv's have a manual button on them that allow you to change channels. If that still doesn't work you may need to do a channel search and then change it to channel three. I will need to know the make/model of your TV to help further.
Apr 07, 2013 | Coby TF-TV3217 32 in. LCD TV
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
Lost remote control , and can't change the channel from 4 to 3 without it. tried another universal remote, but still cant change
Return the universal tv remote where u bought it.Try website like Remotes.com to buy the tv original remote.
Jul 04, 2011 | Mitsubishi CS-27305 TV
I have a bratz tv we've lost the remote... we brought a ge universal remote, tried all the codes listed for MGA tv's nothing worked... HELP
Universal remote control did not work with your tv. Some of them haven't had the desired frequency range to give receaptable signal of your TVs internal infrared reciver. Try an another one, or just try to get a new remote for your tv. Your TV has a model number marked on its back cover. Give it to Bratz and ask them, about the model muber of its orginal remote control, or ask them to send a new one to you. They will surely do it.
Oct 17, 2010 | MGA Entertainment Bratz TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
May 21, 2009 | Samsung TV Remote Control
Tuning tv without remote
u need to call the information number on the tv
May 17, 2009 | MGA Entertainment Bratz TV
I need help my mga tv is set on the right time but wrong am and pm so i cant program my vcr on time record ,. how do i change the t.v. time from am to p m and what is the help line number for me to call....
Howdy Mike-d. here,
Hi Rosebucc,
If you are still looking for an answer to this question maybe this will help.
I have this t.v. here. It does not have a v.c.r. built-in. The time set on the t.v. should not affect the time the v.c.r. records at. What is the model of your v.c.r. ?, that is the device that needs the right time set-so it knows when to record.
Do you have the remote for this t.v. ? I don't, I use a tivo remote instead. It controls volume, mute button, channel, and power on/off.
I don't yet know the help number to call.
The MGA remote has a "Time Set" button in the lower left corner. There are also up and down arrows on the remote. The replacement remotes have "menu" buttons and "adjust" buttons. The right combination of button presses should bring the time results your looking for.
I don't have a manual yet, but if you do, it's probably in there.
There does not appear to be a way to adjust the time the way you want from the buttons on the front of the t.v.
I will post more info if I find it.
mikedee4@gmail.com
Oct 24, 2008 | Televison & Video
MGA 1989 19inch standard tv. - model #CS-1946R
Try this. I the control box under screen (with a door) is a botton TV/CABLE.HCR. Try pressing this button to get more channels. Mine was on TV, but needed CABLE. Best wishes.
Dec 06, 2007 | Televison & Video
Mitsubishi WS-55807 TV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
