Question about Kodak EasyShare M1073 IS Digital Camera
The battery level icon is not displaying on my lodak m1073is
The battery level icon is not displaying on my kodak m1073is when it is turned on. It only appears when the batttery level in really low, which is no use when going out. Can you tell me how i can get this to show all the time?
SOURCE: Camera switches on then off
A friend of mine had the same problem. If the lens cylinder is not just right this will happen. I took my DX7590 and compared it with the Z7590. A square plastic piece just behind the lens was crooked. I removed the batteries and lightly twisted the lense shaft in the direction needed to straighten this piece. I heard a small snap which put the piece back into square. The camera started working again.
Posted on May 18, 2007
osito72009
SOURCE: I have a kodak M1033 camara. In the book it shows
well wha you can do is
Posted on Apr 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak C813 turns off because of low battery - all of the time!
This problem is frequently due to corrosion on the battery contacts. Remove the batteries and clean the contacts inside the camera with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment from the cleaning, then clean and reinstall the batteries.
Another cause that is seen fairly frequently is use of the wrong type of rechargeable batteries. Check the camera's manual. If it calls for Ni-MH batteries, the more common NiCd batteries will not last long.
Good luck, and I hope that this information cures the problem with both cameras. If not, please post again with more details.
Posted on Aug 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
leepania
  • 1099 Answers
SOURCE: Smashed My Kodak Easyshare M1073IS Digital Camera.
OoW. repair 48,44 pounds + postage.
If KODAK cannot fix the camera you will be offered a replacement for the same price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 02, 2009
Lost manuel
The battery level appears in the lower-right corner of the screen. See page 9 of the Extended User Guide: http://resources.kodak.com/support/pdf/en/manuals/urg01241/M522_xUG_GLB_en.pdf
Nov 05, 2013 | Kodak M522 Digital Camera
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
I am trying to find the screen that shows the battery meter so I know when to recharge Kodak 1063MD
Usually, the battery icon will appear showing the battery is low on many Kodak cameras that I have used. There is no % meter that tells how much the battery is charged to my knowledge.
Dec 25, 2010 | Kodak EASYSHARE M1063 Digital Camera
Contact KODAK:
Dec 01, 2009 | Kodak EasyShare M1073 IS Digital Camera
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Kodak M1073IS try to recharge this rechargeable battery but when 'recharged' the lens comes out momentarily then returns
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 20, 2009 | Cameras
Conon powershot a470 i cant find in the manual where the battery life is displayed? is it on the screen? do u have 2 change setting 2 find it? or does this model not display it on the screen?
Your a470 has a "low battery" flashing icon that will appear in the upper right hand corner of your lcd display when the battery is getting low. It doesn't appear to have a constant battery display. The manual recommends when you see the flashing icon... change the battery as soon as possible.
May 15, 2009 | Canon PowerShot A470 Digital Camera
Battery level icon does not appear on camera screen
Just chatted with Kodak, {in Manila} the Tech said the icon will appear when the battery is low.He said you should still be able to take about 15 more pictures once it appears.We'll see I guess.Good luck.
Apr 27, 2009 | Kodak EasyShare M1033 Digital Camera
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Mar 17, 2009 | Kodak EasyShare M1033 Digital Camera
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak EasyShare M1073 IS Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
