Question about Char-Broil CharBroil 4637318 Grill
Char Broil grill does not ignite
I have a charbroil grill not even two years old.. the ignitor fail to click.. replace the battery and nothing.. it a commercial series.. yea right.. I don't see a sprak either.. had to host a big party with a match ligth-up .. :( .. what could be the issue...? also for a stainless steel grill it's begining to have rust spots.. :((((((((((((
  • 36 Answers
SOURCE: Owners Manual for Char Broil commercial Mod 463232103
If you go to the website: www.charbroil.com
and looking under customer support they offer manuals through
their.
If there is anything else I can help you with or if you are needing a part number, please let me know?
Thank you,
Fireplacegirl
Posted on Apr 26, 2008
SOURCE: Need instructions for assembly of char-broil gas grill
Need Instructins for Char-Broil Model 4955526
Posted on Jun 08, 2008
SOURCE: Don't know where to put wood chunks in a Char-broil electric h20 smoker!!
Dip wood chips/chunks in boiling hot water for a few minutes if you're in a hurry or allow to to soak in tap water for about an hour if you have plenty of time. Either way, place the soaked chips around and under the heating element at the bottom. Don't throw out the water; heat it up and pour it in the water pan. Heating it up to boil will give your smoker a good head start. I've been doing that on my char-broil smoker for years.
Posted on Jul 04, 2008
SOURCE: Char Broil commercial grill won't heat pass 300 degrees
The new regulators gas grill made to prevent flair ups when lit. Start with just one knob to lite it wait 3 min put on 2nd burner on low. feel the regulator if it is very cold start again after it warms up. if it is just a little cold warm it up by holding it and turn on the last burner
Posted on Jul 08, 2008
SOURCE: Char Broil Commercial Series
Check inside the burners. You most likely have spider webs inside. Same thing happened to me. Cleaned them out with a long cleaning brush and it works like new.
Posted on Jul 11, 2008
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need a new ignition swicth. year 2005 model DHLB
Whether it's electronic ignition or the old, standard, push button piezo ignitor, you can find it at the Char-Broil Parts Link below.
Happy Grilling!!
May 20, 2011 | Char-Broil Commercial Stainless Steel...
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
My Charbroil grill igniter won't work. Have to
I';m sure everyone thinks they are giving good advice, but READ THE SYMPTOMS. The guy says his ignitor doesn't "click" anymore. And most of you tell him he needs a new gas regulator. Fix his problem, don't create new ones. He needs his ignitor fixed. Maybe just a new battery? Or maybe the whole ignitor unit But certainly not a new regulator, etc, etc.
Jun 29, 2009 | Char-Broil Grilling
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
Char-Broil CharBroil 4637318 Grill Logo
266 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
