Question about Memorex MPS1500 Strip Cut Shredder, With Integrated Waste Basket
Open top how to open top to empty memorex mps 1500 strip cut shredder
    President:
  • 3,085 Answers
Remove the bag holder...look up inside and see 4 screws to remove.
Posted on Jun 28, 2009
Motor runs, shredder wheels don't move
Unfortunately if the motor is running but the shredder wheels are not moving you have probably stripped or broken a gear. Most of the time I have had trouble finding new gears for any brand of shredder unless it is a high dollar model. You might be better off buying a new shredder than trying to fix this one.
Jul 29, 2014 | Omnitech 10-Sheet Micro-Cut Shredder
Do you need to lube a mps-2800
Hello. Yes you do with electrical grease only.
Apr 18, 2014 | Memorex MPS-2800 5 Sheet Cross Cutt Paper...
Do you ever need to lube a memorex paper shredder
ALL shredders need to be lubricated. When metal turns, it creates friction that, over time, can cause the blades to warp. Just like you have to add oil to a car, shredders must be oiled as well. You can buy bottles of oil at your local office supply store. Just squirt across the top of the blades. Or pour some on a plate, dip a piece of paper in it, then shred. If you want less mess, purchase the pre-lubricated sheets that you can just drop in and shred. Make sure to shred in reverse about half way through to get the best results.
220 says bag is full
Well - is it? If so - empty it. Some bags look like they have more room in them, but the "bag full" message lights as a safe guard that it doesn't get filled too much.
Mar 07, 2014 | Fellowes 220 Powershred Strip-Cut Shredder...
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
How can I choose between cross cut and strip cut?
DEPENDS ON THE SECURITY OF THE SHREDDED DOCUMENTS YOU WANT.
A MEDICAL OFFICE WOULD NORMALLY HAVE A CROSS-CUT SECURITY SHREDDER SO NO-ONE CAN PUT DOCUMENTS BACK TOGETHER..ALSO BANKS AND LAW FIRMS.
A STRIP CUT SHREDDER CAN BE PUT BACK TOGETHER IF YOU ARE DETERMINED ENOUGH.
Mar 10, 2010 | Office Equipment & Supplies
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Memorex MPS1500 Strip Cut Shredder, With Integrated Waste Basket Logo
170 people viewed this question
Top Memorex Office Equipment & Supplies Experts
ray gallant
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
