Try SearsPartsDirect.com, RepairClinic.com, AppliancePartsPros.com, EasyApplianceParts.com, CraigsList, and eBay.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
SOURCE: GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
SOURCE: Replacing a Telescoping Power Tower for GE Nautilus dishwasher
Usually this part just unscrews from the top of the sprayer arm...I have researched it and here is a link...you may have to scroll down to see GE specific pump breakdowns....It definitely looks like it unscrews....
http://appliancehelp.hypermart.net/images/gedwpumpassy.JPG
Hope this helps....good luck...and thanks for rating my effort....The Fang.
