Furuno 1715 LCD Radar System GPS Receiver Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Furuno 1715 and the array slows and stops frequently.
I have checked all that I can and have decided that the problem is with the drive motor. I disconnected the drive belt and I can see the motor slow and occasionally stop with no load on it. The unit has less than 12 hours on it. I can't find a replacement motor. The model number on the motor is J262-164. Other info on the motor is CKD RM 9572, 12 volt, step angle is 7.5 degrees 45 ohm coil serial # 5J14. Where can I get one?
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Feb 01, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
0
Helped
45532
Points
190
If you call 410-228-7335 and ask for the service dept, they can call Furuno and obtain the motor for you.
Can i use a gps30 with 1715 furuno
You can interface the GP30 to the 1715 and get Lat/Lon readings where the cursor is. The GPS has extra wires in the power cable. The 1715 will require a NMEA cable pn 000-154-028. Connect the white GPS wire to the yellow radar wire and the blue GPS wire to the green radar wire.
Feb 24, 2014 • Furuno GPS
Like a previous poster, I get "no heading pulse." However, my array is spinning, but erratically. I'm also in Mexico, and would like to pick up repair parts in the US rather than ship the unit to the US....
Adjust the motor mounting so belt don't slide up and down including the tension. Check the cabling connections, axial position sensor and rotor for weather damage. if problem resolved seal the housing with a silicon gel. If belt has visual wear 80% chance thats your culprit. Please be very careful for the magnetron has very HIGH VOLTAGE.
2helpful
Furuno 1715 gives "no heading pulse" error. Image normal, but clocked due to no reference. Pulled heading sensor (4X6X1mm black box, two wires, labeled NRS-101) and checked continuity across leads. Open...
Heading pulse is a reed switch sensor built inside the dome. upon each rotation of the array the reed switch is activated. Do a visual inspection of your array (inside) to make sure it is spinning (verify from a distance). Don't get eye level with the rotating array it can cause great harm to your eyes. Normally I have seen the belt slip off and also the lanyard attachment get caught in the array. Check those two things as well.
My new boat rader the furuno 1715 wil not tune.
Yes and it is in the book a new installation needs calibration!! The rough tuning is off by the sounds of it
1helpful
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
6helpful
2answers
RE: life of the radar magnetron
i have a furuno 1700 radar ,when i switch it on it goes to stand by ,when i press the standby button you can see it scanning but no land appears cheers alan
Furuno Radar 1623 and 1715
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Northstar 952 and furuno 1715
you can connect them by NMEA, but synchronize, no.
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
