Sierra Custom Home 3D
Problem for Sierra Custom Home 3D (63002)
Custom home program has encountered problem and needs to close
By esyst on Jun 28, 2009
I am trying to use Custom home Designer Edition and I keep getting it open and then right before I can use it I get an error message saying the program has encountered problems and needs to close. I've already deleted the file MSVCRT.DLL because I was getting a different error message. Can my program be fixed so that it won't get an error message?
Solution #1
posted on Jul 01, 2009
Somewhat Helpful)
mythman
Rank: Guru
Rating: 92%, 29 votes
Your best option at this time is to perform a complete uninstall-reinstall of the program.
For this, you must have the program installer disk/s and registration (if needed).
** You must have the above stated before proceeding **
From how your described the problem, you are using a version of Windows. You can find the program in your Control Panel, then Add/Remove Programs. Select the program name and click on Uninstall. This is normally an automatic process, and may prompt you to restart the system once completed.
Restart your system and once it is stable, reinstall the application from the program disk using Install.exe (or Setup.exe), or some form of name indicating to setup the program on your system.
This normally takes care of your problem on missing files that the program is looking for, that causes the halt.
If the error still persists, you should contact your Software vendor or the company that provided the program.
Hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Jun 28, 2009
Somewhat Helpful)
yamicazanova
Rank: Guru
Rating: 90%, 196 votes
HI ^^
is this software compatible with your operating system ???
Was this helpful?
Yes
No
Popular Solutions for Sierra Custom Home 3D
Questions and Unsolved Problems for Sierra Custom Home 3D
Do you recommend Sierra Custom Home 3D (63002)?
Answer
Answer
When I select outdoor plants and trees they are enclosed in a blue box. Is there a souution?
Answer
I have had this installed on my XP for more than a year with few problems--none that affected the... (More)
Answer
I read to delete the file msvcrt.dll to fix my problem of not being able to even open sierra home... (More)
Answer
Sierra Home Architect will not let me save any of my work. It will ask if I want to save when I... (More)
Answer
services.exe entry point not found the procedure entry point-resetskoflw could not be located in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sierra Custom Home 3D:
Top Home and Lif... Experts
Rank: Guru Guru
Solutions: 1357
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Home and Lif... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
