Question about Refrigerators
Scotsman automatic ice maker dce 33, poor ice production
I installed this unit for a customer, scotsman dce 33, automatic ice maker about 2 years ago, they are complaining that the tray only fills to about 2 inches at any time. the door seems to have a good seal, water is flowing well, setting is for maxium ice.
can you give a suggestion?
thanks, John
    Dedicated:
    Visited the website for 20 consecutive days.
  • 320 Answers
Possibly the arm that senses the ice amount is too low adjust up
Posted on Dec 09, 2017
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Posted on Oct 20, 2007
  • 864 Answers
SOURCE: No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
Posted on May 30, 2009
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: i have a scotsman dce 33 it is 10 years old. Service man said it has a leak and is a sealed unit. I would need a whole new sealed unit. Could this be repaired by putting a valve in line, fixing the
What I gather from the technicians remarks are the whole sealed unit and he leaves out the defined area of the leak. Sometimes leaks like this are really difficult to find and repair especially if the ice machine is still in use. To answer your question yes it most likely can be fixed if the leak location is found, fixed, pull another vacuum and recharged with Freon, If you have more questions I will be here to answer them for you, Sea Breeze
Posted on Nov 27, 2011
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Do i need to oil the spray pump on my DCe 33 Scotsman ice machine
You can spray lubricant of a silicon base into the rotating part, but you will need to replace the pump.
Apr 27, 2012 | Scotsman DCE33PA1BC 15in Built-in...
I have a scotsman dce 33 it is 10 years old. Service man said it has a leak and is a sealed unit. I would need a whole new sealed unit. Could this be repaired by putting a valve in line, fixing the leak...
Nov 27, 2011 | Scotsman DCE33PA1BC 15in Built-in...
I have a CSX45A1D Scotsman under the counter ice maker. Need manual for this unit. Thanks Dennis
Hi I think your model is the csw45 if it is then you can download the manual from http://www.scotsman-ice.com/docs/uploaded/sct/manual/Csw45m.pdf
Jul 29, 2011 | Scotsman CSW451D 15" Ice Maker with 26 lb....
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Oct 21, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
