Question about Alpine CDA-9883 CD Player
The harness wires
What wires are hot and which ones are not
    Problem Solver:
  • 12 Answers
It tells you on the cd player,the red wire goes to the +12 volt switched,and the yellow one to the +12 volt constant wire,the black wire to ground ;)
Posted on Dec 15, 2009
Why is wiring harness getting hot when cables are installed on new battery?
the harness is getting hot because of excessive current draw in a wire in the harness
This indicates a fuse of the wrong amperage in a slot because the fuse is designed to blow before the wires get hot.
Feb 19, 2015 | Cars & Trucks
Installing an after market radio harness but do not have a solid orange lead to connect out of the factoryharness
Most after market radios has a wiring diagram and the wires are tagged, but are wired the same, you should have two hot wires, one will be hot (12 volts) all the time for memory and the other will only be hot with the switch on. you can check with a test light, make sure your black wire is grounded. hope this helps.
Jun 03, 2014 | 2004 Chevrolet Monte Carlo
Have a 86 camaro with a 2.8 engine installed but cant rember where the wires reconnect from the wire harness. These wies have ring eye lets on them.
Are the wires harnessed together? Is there a connector on the end? Colours are decipherable on a chart. Is cold wire hot when ignition set to acc or on? Was there an aftermarket piece there before?
Feb 24, 2013 | 1988 Chevrolet Camaro
How do i wire a sidecar to a 2003 fatboy
The only thing there is to wire is a tail light and a stop light. tap into the wires running under your rear fender going to the tail light assembly. Turn on the switch, and test the two wires. One will be hot, this should be the tail light. Go to the other wire, it should be "cold", step on the brake pedal and it goes hot. This is the brake light wire. Use those crimp on splicers like they use to wire trailers on cars with. Put the splicers on the sub harness going to the tail light not the main harness. That way, if the wire is damaged, you can buy a sub harness much cheaper than a main harness and it's a LOT easier to put on.
Good Luck
Steve
Jul 31, 2010 | 2003 Harley Davidson FLSTF Fat boy
Radio wire harness cut
You can buy a kit from a number of sources to solve this problem. Instructions come with the kit. If you are putting a stock radio back in go to a junk yard and cut the loom out of another truck and marry it to your truck. If you don't want to do either of these things the fat red wire is almost always hot. The antenna cable is unique and will only fit in one spot. the speaker wires are small diameter and will work no matter which way you hook them up as long as one hot (speaker) wire and one ground wire go to each speaker. Have fun.
Mar 19, 2010 | 1990 Isuzu Pickup
No spark or fuel 1991 dodge dakota even if i hot wire the coil no spark i hot wired the fuel pump got gas to throttle body but when you give it full throddl no gas to moter.
I know it's a long shot without looking at it or more information. Look under the hood on the left (drivers) side center of the fender at the wire harness. The one inch diameter or so wire harness running along the fender. Look for any green spots or even open the harness up a bit to look. The ASD relay wire runs through that harness. I've found a few corroded in two with the same symptoms. I think the washer bottle may be over the harness, not sure. Like I said, it's a long shot. I hope this helps.
Apr 23, 2009 | 1991 Dodge Dakota
Electric radiator motor shorted to ground and burned wiring from motor thru harness. fusible links also. to get home bought new fan/motor assembly and wired hot to run all the time. My problem is what to...
yes you can get a new wiring harness,from your plymouth dealer, or junkyard. its best to get a new one because they always are improved from the original.
Jul 28, 2008 | Plymouth Sundance Cars & Trucks
Wiring harness or Battery Cable Harness?
I dont know if this will help but vI had the same problem with my farm tractor It turned out to be a short in one of the wires cant remember vwith one. try tracing them from the batery back
Jul 11, 2008 | 1996 Ford Windstar
Alpine CDA-9883 CD Player Logo
44 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
