Question about Kenmore Elite Oasis 27052 Top Load Washer
Turned washer on side to replace part. now makes loud noise and basket wabbles when spinning. how does triangular part fit under tub? This may be off and not in place correctly. Also two what appear to be pins are to be in what position?
    Genius:
  • 1,122 Answers
If you lay it on it's back the 2 sides og the triangle face forward,also look at the pads under the triangle to make sure there good,the pins you see are for shipping purpose only-mike
Posted on Jun 28, 2009
When the machine starts to spin, a loud thumping noise starts.It sounds like it's hitting against the tub from underneath.The tub isn't off balance.we looked under it, didn't see anything broken.
check counter weights and suspension springs or rods then look for LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, DRIVE BLOCK, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Another noise issue can arise from a worn SNUBBER RING on some washers that have a snubber like some Maytags, if u notice tiny pc's of white/grey shavings on the floor or around the bottom washer area? A sign of bad snubber. When removing to replace be careful as the spring underneath is pressure loaded.
A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
One Way To Test For Spin Bearing Noise Is To Lift Up Top Part Of Machine With The Lid Taped Down, Explained Below, Put It In Spin Cycle, AndQuicklyPlace The Palms Of Your Hand Inside Of Basket Pushing Against Opposite Ends In The Basket To Stop It From Turning, Yes It Can Be Done Because It Takes A While Before It Starts Spinning At Full Speed, If Noise Has Gone Away, Its Your Spinner Bearing. Do Not Repeat Until You Stopped The Machine And Start Over Again. The Same Kind Of Noise Can Also Be A Bad Water Pump, Which Are Known To Fail And Have Since Been Redesigned, But That Noise Will Be Heard In Spin And Agitate Mode, And The Noise Will Have A Higher Pitch Sound, More Like A Screeching Sound.
Apr 13, 2017 | Washing Machines
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
SPINING MAKES LOUD NOISE
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
GRINDING NOISES:
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a LG WM3987HW combo washer dryer that is also making the roaring noise on spin cycle
GRINDING NOISES:
May 31, 2012 | LG WM3987HW 4.2 cu.ft. White Front Load...
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Maytag Neptune Washer
Suspension plate
The suspension plate should be loose and float between the frame and base. The pin you saw was a shipping pin, they usually are caught in a little plastic cup attached to the base but sometimes fall to the floor, this is normal too. The tub being loose is normal for the top, it is held down by the springs below the tub but nothing on top. By a loud noise, what kind of noise is it? If it is a very loud ratcheting noise when it slows down then the basket drive(spin tube) and block need to be replaced. If it is a growling noise then that is pump and may be normal if the basket is not spinning. If this is the case look very close for an article of clothing caught between the tub and basket.
Apr 19, 2010 | Estate TAWS800JQ Top Load Washer
Washer FTR630ASO Fridgedaire - inside tub is loose and loud
we've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Oct 08, 2009 | Washing Machines
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Rear bearing noise when drum rotates
If the rear bearing is bad it will require the replacement of the entire rear tub shell. This is because the bearing is molded into the plastic and cannot be replaced separately (I know, its a stupid design). Sometimes additional damage can occur and the inner spin basket and front shell may also need replaced. In addition, what may seem like a bad rear bearing, might be a broken tub support on the spin basket. In a nutshell, you may have to replace both tub shells and spin basket at a minimum. With parts and labor the repairs could cost $600-$800. If you have no extended warranty or service plan coverage, it may not be worth the effort to repair due to the excessive cost. Sorry...I wish I had better news for you. I hopes this provides you with some answers.
Oct 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
