Back to:
Tags:
Lexmark Wheelwriter 1000 Typewriter
IBM quietwriter 7 - autocorrect problem
posted by TeddyTested on Nov 07, 2007
Hi
I used to use (and am familiar with) IBM wheelwriter 6.
I bought a used IBM quietwriter 7 at a local garage sale.
I cleaned it up and it was working properly - autocorrect and all.
Then the tape/ribbon broke in the print cartridge.
I opened up the cartridge and re-attached the take-up ribbon by removing what was left on the used-ribbon take-up spool and attaching to the hub with krazy glue. I put it all back together - everything works great.
Until I went to autocorrect.
I get black blotches instead of erasing/correcting.
What I thought was odd about quietwriter is that it doesnt seem to have a correcting ribbon cartridge (like wheelwriter did).
SOOO.. I am not sure how the autocorrect actually FUNCTIONS on this thing.
I am wondering if I incorrectly threaded the ribbon through the cartridge (it looks exactly the same as it does in all the pics of the cartridges I could find online). cartridge # is 1299635 - IBM 'quiet' high density correcting ribbon.
I also may have incorrectly threaded the ribbon through the machines mechanism - but it seems pretty automatic.
I'm pretty maechanically / electrically / electronically inclined and can fix most anything (properly) without giving much effort to it - it's just a gift.
But this one has me stumped.
I do NOT have an owners manual for this machine - are there any sources to dlownload them online (for free?) $45 is a bit much for a machine I paid $3 for.
I was hoping to try to sell this on ebay for afew bucks if I cannot use it myself.
Please help?
thank you kindly.
Ted B.
tcb_pc@yahoo.com
Comment by TeddyTested, posted on Nov 11, 2007
Actually, I have since gotten the machine to correct properly.
The IBM Quitewriter 7 does NOT use lift-off correction tape like wheelwriter does. It seems that the typewriter mecahnism needed to be cleaned more thoroughly (with dealcohol) and allowed to dry completely.
The machine now corrects flawlwssly.
I still, however, do not understand how a single black ribbon cartridge machine can also correct - but it does.
it goes back and somehow strikes and erases the carbon right off the paper - no lift-off correction tape is required (or available) for IBM quietwriter 7.
TYPO- should be DENATURED ALCOHOL.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 07, 2008
Not Rated (0)
samnjst
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've been a IBM typewriter technician for 15 years in the field. Currently I support Servers for a major bank data center. Concerning the lift off I think the print heads correct with a negative and prints positive charge similar to a laser printer of which I am an HP certified tech as well.
Regards,
Sam
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM quietwriter 7 - autocorrect problem:
I don't want to Accept this solution
Solution #2
posted on Dec 28, 2007
Not Rated (0)
DickyO
Rank:Guru Guru
Rating: 89%, 183 votes
When a Quietwriter corrects the the print head heats the ribbon just enough to make it tacky and remove the print.
I hope you can sleep now.
DickyO
Thank You!
Solution #3
posted on Nov 07, 2007
Not Rated (0)
JUSTOLDJIM
Rank:Wiz Wiz
Rating: 78%, 106 votes
Do you have a lift off tap snapped onto the bottom of the ribbon
Rating Locked! (?) TeddyTested has rated this solution as Not Rated
Thank You!
Can you Help with these Typewriters problems?
Typewriters
have been given Brother AX110 electronic typewriter but no...
Typewriters
I have a smith corona XL 1000 typewriter that i haven't...
Typewriters
Would like to continue where I left off last night with...
Typewriters
continue live help from last night with marked.
Typewriters
Was typying and it just quit, and will not do anything...
Loading problems.
Repair Service
Find Typewriter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
