Question about Frigidaire FRS26ZSG
I have had my Frigidaire FRS26ZRG for 10 years. Last week it stopped working. I had it repaired about 5 years ago and I don't really want to put too much more money into it. I would like to know if the compressor is going bad or could it be something simple. The refrigerator side is not getting cold at all. The freezer is not working properly but you can feel some cool air but not cold enough to keep food. Any suggestions?
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
Posted on Feb 17, 2008
aborcass
  • 2651 Answers
SOURCE: I HAVE A FRIGIDAIRE REFRIGERATOR
if needs sealed system repair problaby cheaper to buy new. try removing the back wall of freezer section, is there excessive frost build up??? is the fan behind tere even running(if not replace hte fan). if theres frost built up hten look for a defrost problem. Perhaps a defrost timer, defrost thermostat, or even a bad heater assy. if you remove to coil adn find a ball of frost in 1 corner nad rest of evaporator is clean and dry, thats an indicator of sealed system problem
Posted on Mar 22, 2008
SOURCE: my frigidaire refrigerator does not
Had this same problem. Ice formed on the back of the freezer compartment, but the refriderator area would be about 50 degrees. Checked the fan and defroster timer and everything worked fine. Watched it all defrost and ice build up again. Finally called for service. First guy said he needed to take the unit back to the shop. Second guy said there was an internal leak in the sealed case...couldn't be fixed. Finally realized I had bought an extended warranty (yippee!!) and called the authorized service dealer. Tech came out, said there was a service bulletin whereby the freon line by the evaporator coils was bent a little to extremly and was causing a restriction in the freon...thus the ice build up. He tweaked the line a little and now it has run perfect for 6 months. Would be nice if these bulletins from the factory were posted somewhere...
Posted on Oct 05, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
  • 1122 Answers
SOURCE: refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
Posted on Dec 06, 2008
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a 10 year old Kenmore top freezer that clunks when it shut
its the compressor,
i would not spend a dime on it,
a compressor is around 200 to put it in could cost up to 200 more, then its a long shot with who will be doing the work
10 years is the avergae age of this unit so count your self lucky
and invest in a replacement
the old one may
last a year, but it will go
your loosing the center seal
sorry its not beeter news
Oct 05, 2009 | Kenmore 64802 Top Freezer Refrigerator
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
639 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
