Question about Coby MP-C781 MP3 Player
How do i delete everything on my coby? - Coby MP-C781 MP3 Player
Accidently deleted firmware on my Coby mp200 mp3 player. Please help to find and reinstall
accidently deleted firmware on my Coby mp200 mp3 player. Please help to find and reinstall
Oct 18, 2009 | Coby MP-200 MP3 Player
Ok so I have a coby mp3 player and the songs are
Ok there are 2 Solutions that can fix this:
First:
1. Plug the MP3 player into the USB port. Open Windows Media Player, which will recognize that the device is plugged in and register under the "Sync" tab at the top.
2. Click on the "Sync" tab and and the library that is on your MP3 player will be displayed.
3. You can select individual songs or albums for deletion. Simply right click on the song or album to be deleted and scroll down to the "Delete" option.
4. After selecting "Delete," another window will come up which says "Are you sure you want to delete [title of song]?" There are two options at this point--you can delete from the library only or from the library and your computer. Select the one or the other and click
"OK." The song will be deleted. The change will be displayed within the library onscreen.
5. When you unplug the player from the port, the library will adjust the files to reflect the change. The player will say "configuring library" or some other message to that effect. Once this has finished, the main screen will be displayed. Depending on the model of the MP3 player, there may be a message stating "library updated."
Or if that does not work try this:
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Coby's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 03, 2009 | Coby MPC-848 MP3 Player
Deleted songs are still there!
I agree with profalwg, use Windows Explorer. When you connect the player's USB cable to the computer, a window should open...click on the option to open with Windows Explorer. If you delete files and they still don't go away (happens sometimes) go into the player's Setup menu & change the USB setting to MSC. Doing this corrects 99% of player recognition problems. Hope this helps!
Jul 29, 2009 | Coby MP-705 Digital Media Player
Deleting files is not creating free space on my coby mp705-8g mp3
Ok First, Open Your MP3 player
2) Go To Setup
3) Then Go to system
4)Then Usb Mode
5) there will be auto or MSC
6) choose msc and then plug it in the files will be there.
Mar 11, 2009 | Coby MP-705 Digital Media Player
Coby MP3 player is full but songs do not show up on my computer
Hello!!
try reinstalling the mp3 player drivers if u have .. or last option is to format it ... And also check out whether the player has a reset pin on the outer part .. if u find it .. try resetting it!!
Thank you!!
Jan 12, 2009 | Coby MPC895 MP3 Player
My Coby MP-705 Won't Let Me Delete Songs
Just format your player and it should get rid of everything, including the preinstalled junk. Right click 'internal storage' and select format.
Jan 03, 2009 | Coby MP-705 Digital Media Player
My Coby MP-705 Won't Delete Songs
I had the same problem - VERY frustrating. Just found the answer, and am very happy to share it!
1. In setting/USB mode, select MSC mode.
2. Plug in Coby to USB
3. Open My Computer. Look for the Coby as a REMOVABLE DISK, not the Coby.
Files will be there for Viewing and Deleting! (On XP, at least).
4. Make a backup of MTP.BIN and WMPInfo.xml, which I think is the operating sytem?
I got the clue from here:
http://www.fixya.com/support/t357600-problem_coby_mpc7095_2_gb_mp3_player
Paupaul
Well, turn on you mp3 player, go on setting/USB mode and select MSC mode.
Then plug it on your computer and check in MICIN.DIR folder. You must find them.
It wasn't exactly what I saw, but once I looked, it was all there. Perfect!
Coby MPC7095 2 GB MP4Player Problem
somebody formated it and that deletes everything off of it.
just plug it into your computer again and wait until it works.
Mar 04, 2008 | Coby MP-C7085 MP3 Player
Coby mp-833
Download the proggy for the unit and format the memory, If its a usb unit that needs no drivers and self installs that you can browse try deleting everything you put on it and try again 10 songs at a time. Most likely there is a corrupt file in there.
Sep 15, 2007 | Coby MP-C883 MP3 Player
Coby MP-C781 MP3 Player Logo
46 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
