Question about Smeg 18 in. DWF409WH Slim-Line Free-standing Dishwasher
My Smeg dishwasher DF410BA has a problem
I switched it on last night and noticed that it took longer than usual to complete the cycle. Also it was making this noise as if it was pumping water out but no water was coming out. I have tried to reset the machine back from factory settings back as soon as i switch it on this water pumping noise keeps coming on. Can anyone help. Andy
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Posted on Feb 10, 2007
zeusfaber
  • 247 Answers
SOURCE: Smeg Dishwasher
This is usually the heating element - corrosion lets small amounts of water through the element jacket, making the mineral insulation inside slightly damp. When the machine applies power to the element, enough current leaks from live to earth to trip the RCD. In the absence of a proper electrician's insulation tester (a DVM in ohms mode doesn't test at a high enough voltage to give a meaningful result) the best way to prove this fault is to (carefully, and with the power off!) disconnect and tie back the wires that go to the element, then run the machine and see if it gets any further in the cycle. A.
Posted on May 17, 2007
  • 3422 Answers
SOURCE: Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Posted on Feb 23, 2008
  • 333 Answers
SOURCE: NO WATER COMING THROUGH ON DISHWASHER JUST LOUD BUZZING NOISE
The buzz that you hear is the water line solenoid. It probably is not opening up to let the water through. You should replace this solenoid and it will fix your problem as long as you have water coming up to the diswasher's solenoid valve.
Posted on Dec 03, 2008
SOURCE: Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Posted on Aug 11, 2009
My smeg Module DF 612 SDX7 dishwasher tripped the circuit last night early into its cycle. We could smell burning coming from the dishwasher. Any ideas and what we can do to fix it?
If you can get it to operate for a few seconds, that will at least tell whether the motor is still good and turns freely. Otherwise it sounds like board may have failed.
Jun 21, 2015 | Smeg Dishwashers
665 dishwasher
If the door is not locking properly there is a chance that the door lock switch is not being closed. This will shut off power to many of the circuits, including power to the water fill solenoid, etc. Latch mechanisms are available separately.
Sep 19, 2017 | Galaxy Dishwashers
Took out filter to clean noticed water in tank
yes....most leave a little behind as the pump out hose is higher than the pump..
Jul 20, 2010 | Smeg 24 in. DWF612WH Free-standing...
Smeg dishwasher E1 error code, not filling up
Hi!
here are manuals to the number of SMEG dishwashers.
Hope you could find there your device and the "troubleshooting" part of it would help you!
https://manualsbrain.com/en/brands/smeg/dishwashers
Dec 07, 2017 | Smeg Dishwashers
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
Goodluck..
Feb 23, 2008 | Dishwashers
Smeg dishwasher
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Open Questions:
See all Smeg 18 in. DWF409WH Slim-Line Free-standing Questions
Smeg 18 in. DWF409WH Slim-Line Free-standing Dishwasher Logo
390 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
