Question about Toshiba 50HP66 50 in. Plasma Television
My Toshiba 50HP66 will not turn on. It powers up like it is trying to turn on, then it makes a clicking sound and turns off. It will do this over and over until I unplug it.
  • fmvays Jun 28, 2009
    Thanks for help. I did some home work as followed:
    1.Power doesn't turn on : Is F3900 broken? - no (checked)
    2. Is there voltage at pin 11 of cp3201 5v? - yes (checked)
    3.is there voltage at pin 2 of ic3804 at 3.3v? - yes (checked)
    4. change Scaler PCB.
    This is what troubleshooting guide tells me.
    Is the scaler PCB common problem?
    Should I look for this board now?
    What is your suggestions?
    Thanks a lot.
    v\:* {behavior:url(#default#VML);}
    o\:* {behavior:url(#default#VML);}
    w\:* {behavior:url(#default#VML);}
    .shape {behavior:url(#default#VML);}
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    President:
  • 1,077 Answers
Most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • Devon Sacco
    Devon Sacco Jun 29, 2009
    yep. start looking for the Scaler PCM. The guide should identify the part for you. You should be able to find a replacement part with the part #, Just run the part# on google search and someone should sell it.
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66--can't change channels anymore
Have you tried to unplug set for a while and turn back on?
If that does not help contact Toshiba to see if common problem on this model and if any possible software upgrade is available for this problem.
If still no luck someone will have to examine it and decide which board is causing this and replace it.
Mar 22, 2012 | Toshiba 50HP66 50 in. Plasma Television
My toshiba 50hp66 cant turn on with the remote unless I press any of the side panel buttons besides the power button.
What you are reporting does not sound like any problem I have heard before.
I suggest you contact a TV repair guy and have them come out to take a look at your set. You may possibly have an infrared signal/circuit board problem.
Nov 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50hp66 The tv shuts off and the red light
Sounds like a system failure - one of the controller boards may have gone bad. If the unit is still under warranty, contact Toshiba for warranty service. Otherwise you will need to contact one of the authorized service centers or your local TV repair guy to arrange for repair.
Nov 08, 2009 | Toshiba 50HP66 50 in. Plasma Television
Can hear sound but no picture on a toshiba plazma 50hp66
There's a possibility of the screen not getting enough voltage from the power supply so u should get tha voltage to the lcd cheked .votage has to be enough to run sound and video
wish u the best .
Aug 31, 2009 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
50HP66 Plasma TV wont turn on fully. I hit the power button. It goes green for like 3-5 seconds then go back to red off light. It continues this untill I unplug the TV.
did you get your tv fixed? have same problem last night...a loud click and then blank screen and just tries to turn on, can you email at res116@comcast.net
May 18, 2008 | Toshiba Televison & Video
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
No Picture
It's the Y-Sustainer problem. However, they normally change the Y-Sus and Z-sus boards at the same time. It's a costly repair.
Nov 14, 2007 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 50 in. Plasma Television Logo
856 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
