Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
The door is shut on my front load washer. However, the machine will not run. I get the following message ERR LOC.
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Posted on Aug 05, 2009
  • JackiSimone Elliott
    JackiSimone Elliott Oct 12, 2013
    Thank you So Much!!! I called Sears repair who said a techician for the same problem. They said they could come out to give me an estimate for $75 or I could purchase a warranty for $219.99 for repairs and parts up to $500 total. I did what you suggested and pushed OP
    Thank you So Much!!! I called Sears who would not give me a reason for the LOC symbol. Finally after calling the 3rd time, a technician said it was a door loc issue. They said a technician could come out for an estimate at $75. Also, I could purchase warranty for $219.99 for repair of front loader with parts and labor up to $500. I did as you suggested pushing "OPTIONS" and "SELECT" and It's Working Again Perfectly! What a Relief!
    Problem Solver:
  • 11 Answers
The washer is not broken, that means the control panel is locked,(child safty feature), press the two buttons with the pad lock symbol in for 3 to 5 seconds and that will unlock it!!
Posted on Nov 15, 2009
  • Katie Nov 26, 2012
    This was very helpful!! For my frigidaire front loader you press the Options and Select buttons at the same time to solve a LOC ERR. That is the large options button with the select button at the same time, took about 3 seconds!
  • Jane Murphy Feb 04, 2013
    After a very frustrating 20 minutes, I finally found this solution and it worked brilliantly! Thanks a million>
How to solve error loc on frigidaire front loader
Posted on Aug 12, 2009
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer wont start it says LOC when i push the star button then err this is a front load frigidaire gallery
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Jun 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
MY fridgadaire lg washer says loc and wont let the door lock and machine start
That is a door lock malfunction, check the lock and wire harness connections.
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
1,589 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
