Question about Soyo Computers & Internet
SY-K7V DRAGON Plus no longer boots.
I have a system based on an SY-K7V DRAGON Plus motherboard (VIA KT266A chipset).
Yesterday, I got some weird program exceptions and decided to reboot the computer to see if that would clear up the problem. I have never gotten back into Windows since.
At first, it would get through the initial checks and prompt me about whether I wanted to go to safe mode or load windows normally. No matter which choice I made, the next thing that would happen is that there would be a flash of a blue screen (it was so short that I could never read what it said) and the the computer would reboot again.
After a couple rounds of that, it now won't POST at all. When I apply power, fans start running, optical drives spin up, there is a little bit of hard drive activity, but nothing comes up on the monitor and eventually, it all quiets down except for the fan. No beeps of any kind.
Any ideas what might be the problem?
  • jason_nearin Jun 28, 2009
    I would have expected to get some beep codes if the memory was not properly seated.
    In any case, I tried pulling all the memory out to see if I would get some beep codes and the behavior was unchanged. Seems like there is something that prevents it from even getting to the memory check. Maybe my CPU is dead?
    OK. It'll take me a while to scavenge an alternate power supply from another machine, but I'll give it a try.
    Thanks for your help.
  • 61 Answers
Try reseating the memory and restarting the PC. If that doesn't help and you have multiple sticks, try removing all but one, then cycle through to see if maybe you have a bad stick somewhere.
Posted on Jun 28, 2009
  • lazyart Jun 28, 2009
    Could be. I'd next try a different power supply, then a CPU (a failing power supply could spin the fans but not deliver enough power to start the system).
I changed some BIOS settings for CPU speed and memory, now it wont boot - how do i reset the BIOS back when I cant get to the BIOS screen? Soyo K7V Dragon motherboard
Hi:) Turn the computer off but leave it plugged in so you have no static problems. Open the computer tower and on the motherboard near the Cmos Battery there is a blue or red jumper that covers 2 of 3 pins move it to the other side of the 3 pins for 30 seconds then put it back that will reset the bios to default.
Mar 07, 2011 | Soyo SY-K7V Dragon Motherboard
What does three long beeps soyo sy-p4vgm indicate? Everything was running well. Powered down, powered up..beeps thanks
might be a faulty connection/lead make sure they have secure connections
test all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also cd/dvd/3.1/2 inch floppy drive leads
hope this helps
Sep 30, 2010 | Soyo SY-K7V Dragon Motherboard
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Where can I get a manual for my KT600 DRAGON PLUS V2.0
I have a PDF file for SOYO KT-600 Dragon Plus V2.0. I can email it to you.
Oct 15, 2009 | Soyo SY-K7V (SY-K7VKPE) Motherboard
Computers & Internet Logo
91 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
