Question about Ungo SR6000 2 Way Security with Remote Start Combo System
2006 tacoma will not unlock when remote started. also dash lights and parking lights flash when remote started.
    President:
  • 676 Answers
May not be programed to lock in remote start, secondly if programmed lights will flash while in remote start.
Posted on Jun 30, 2009
Park lights come on in a2008 gmc 2500 hd diesel when left parked not running factory remote start just died also any suggestions
lights stay on for short time after turning off vehicle or when you hit lock or unlock on fob as to auto start either fob battery died --fob malfunction--or you have a check engine code --have vehicle scanned because a pending trouble code may not light up on dash but will disable remote start --if it is a fob problem and you lost programming need to go to a dealer to flash the remote start
Jul 07, 2016 | GMC Cars & Trucks
My 2006 Silverado ddl's work but will not come on. I have replaced the bulbs and they work. When you use the key pad to unlock the truck they come on. But will not work while driving.
The daytime running lights should not flash when locking/unlocking the vehicle. It should be the park lights that flash. You may have changed the wrong bulbs. These lights operate from a sensor located in the center of the dash and use the suns ultra violet rays to go from daytime lights to headlights. Make sure this sensor is not obstructed/covered by anything that may be on top of the dash.
Jun 06, 2015 | 2006 Chevrolet Silverado
2006 toyota tacoma trd automatic wont start
join www.tacomaworld.com and go there to ask this question
Apr 19, 2017 | 2005 Toyota Tacoma
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Everything on my viper 5601 system install on a 2006 Dodge Ram 1500 works except the remote start
Check the toggle switch, usually mounted under dash. It's simple on/off switch. Or it's your hood pin switch.
Or tell me how many times your parking lights flash when you push the remote start button and I'll def tell you the issue.
Aug 12, 2010 | Viper Security and Remote Start System...
Where is the fuse or relay transmission shift lever lock of the 2006 Tacoma
If your transmission lever will not come out of Park, you have a blown Brake fuse, or a bad brake switch above the brake pedal.. The fuse is in the interior fuse box, under the dash, driver side.
We hope that this helps you out.
Dec 29, 2009 | 2006 Toyota Tacoma
Parking light malfunction
The remote starter is the culprit. Your vehicle has a body computer, and it is not programmed to understand the installation of a remote starter. More often than not, the remote starters cause very bizarre things to happen to the body computer. Best advice: Remove the remote starter before it causes permanent damage to the body computer. A BC replacment is over $1,200 dollars.
Feb 05, 2009 | 2006 Toyota 4Runner
Flashing maintenance required light
NEEDS AN OIL CHANGE. YOU CAN RESET IT YOUR SELF. HOLD IN THE "TRIP" BUTTON AND TURN THE KEY ON (DO NOT START IT) 5 DASHES APPEAR AND DISAPPEAR 1 AT A TIME THEN 5 "0"'S AND YOUR DONE. SOMETIMES THEY HAVE TO BE ON "TRIP A" BEFORE YOU START
Nov 17, 2008 | 2006 Toyota Tacoma
Ungo SR6000 2 Way Security with Remote Start Combo System Logo
201 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
