Question about LG Heat cool Window Air Conditioner
LG AC compressor problem
I have an LG AC and it seems that the compressor starts to kick on but the boggs down and goes off.... it is only 1 year old. I unplugged it so it may reset itself but still does the same thing. Worked great last year.
  • 3 Answers
Sounds like the unit is "stuck" in Dry Mode. I have the same problem - unit used to work great, but now the compressor only runs for one minute at a time. Mine is only 2 months old (LG 8008R).
Posted on Aug 11, 2009
    Scholar:
  • 70 Answers
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Posted on Jun 28, 2009
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Car boggs down when condenser fan runs
Hi Roger, I believe that you have more than one possible problem. The first is if the belt is not tight enough it will squeak. If the vacuum tubing to the relays controlling the up idle are broken or leaking the up idle will not work and as the drag caused when engaging the AC is substantial the engine revs will drop or can cause the engine to stall. If there is a problem with the AC compressor, it can also cause the symptoms you're reporting. The sound of the fan operating will increase with the volume of air circulated, which is normal, but I'm not sure what sound you're referring to? Regards John
May 03, 2012 | 2003 Ford Focus
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
I have a ARP-30125 portable A.C. just about 1 yr
try a hard start electronic relay(it has a big capacitor to give it extra kick to start) clean both fins...oil fan motor
Aug 18, 2009 | Heating & Cooling
Compressor kicks on for about a min then shuts down overload trips out
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Ac window unit comporesser doesn't kick on consistantly
try switching off and on power from the plug it might reset itself
Jun 22, 2009 | LG Heat cool Window Air Conditioner
A/C compressor fan won't turn on by itself.
there is a problem with your fan i'm sure. change the bossing of your fan it will work good.
May 20, 2009 | LG LB8000ER Air Conditioner
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
LG Heat cool Window Air Conditioner Logo
819 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
