Question about Dryers
Dryer drum vibrating - Dryers
  • 82 Answers
Can be the felt bearings or the main bearings on the back i need to know the make and model No
Posted on Jun 28, 2009
GE Profile DPVH880EJWW dryer makes a grinding sound and vibrates intermittently. Any idea what causes that. I was thinking the drum glides.
look an see if the front seal on dryerdrum is rubber again front dryer cabian look for melt shaving in dryer drum are drum support an dryer pulley is warn out
Sep 25, 2015 | GE Dryers
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
LG DLE3733 loud vibration from bottom
If that vibration is while running it may be from an imbalance of the clothes in the drum. Open the door, when the drum stops reorder the clothes around the drum and see if the rumbling stops.
Jan 22, 2013 | LG DLE3733 Electric Dryer
Loud vibration
Lot of these dryer had a split or defect in the drum. They will give a free drum but ya gotta pay labor to replace it.
MY LG dryer service manuals and repair videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 16, 2012 | LG Home Applaince LG DLE2301W 7.3 Cu. Ft....
GE Dryer DBVH512EF0WW vibrates/shudders excessively. Particularly with the top on. I've replaced the front top bearing, drum slides and felt seal. What is my problem?
The only thing I can think of is if you have plastic inserts built into the drum then maybe you installed the wrong kit in the dryer.
Their are basically 2 styles of GE dryers. Those that have a steel drum and a bearing with glides on the front panel and those that have felt on the front panel and the plastic glides mounted in the drum itself.
Oct 12, 2012 | GE DCVH515EFWW Electric Dryer
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
Vibrations when drying
Unplug the dryer.
Take a putty knife and push the clips in between the front panel and the top lid.
Raise the top back, out of the way.
Inside the right and keft front sides of the front panel, remove the 2 screws.
Remove the wire connector to the front door.
Set the front panel aside.
Remove the screws from the blower wheel cover on the bottom left and check the blower wheel for free play on the motor shaft.
If free play is there, replace the blower wheel.
Reach underneath the drum and remove the belt from the motor pulley.
Lift the drum(it will take some force) by pulling the rear of the drum up.
Then pull it out.
The drum support is attached to the rear of the drum. The drum catch is mounted at the rear of the cabinet and is U shaped.
Replace both these parts.
Re-assemble and run your dryer.
Apr 05, 2009 | Frigidaire FDG546RE Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore electric dryer vibrates loudly
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
Dec 15, 2008 | Kenmore 659 Electric Dryer
Vibration
I had a technician out who said it is the nylon wheels - when it's cold outside the dryer drum is cold - once you start the drryer ( I know it's very loud) the wheels warm up and quiet down - you can order new wheels I think - different material.
May 13, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
114 people viewed this question
Top Dryers Experts
