It starts walking on spin cycle.Just recently started to do this.
  • 82 Answers
What make is it
Posted on Jun 28, 2009
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
Spin cycle does not remove excess water (worked great till recently)
EITHER A LOOSE WORN OR BROKEN BELT, A LOOSE SLIPPING CLUTCH A BAD DOOR SWITCH
Apr 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
The washer will drain but the spin cycle will not start; It just makes a bad noise like the motor is running, but no spinning.
sounds like the motor coupler is bad. its not too hard to fix. there are videos online that will walk you through the process
Jan 17, 2013 | Washing Machines
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
Washer walks on spin cycle, leveled unit and put carpet under it and it still walks on spin cycle only. I have had this washer for 7 years, just started recently doing this.
This is a sign of machine out of balance. If it has been OK for some time, until now, I would look at the balance springs (usually three of four holding to bowl to the outside of the machine, and see if one has come off, or is rusted through. Either fix or replace.
Does the machine spin just fine with no washing in?
2TRP
Jan 13, 2010 | Maytag PAV2300 Top Load Washer
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
No spin cycle
Probably a bad timer. Do you have a Multimeter? If so, I can walk you through the tests for a timer. If the timer is bad, it will not tell the machine to start the spin cycle. Let me know if you have Multimeter or Ohmmeter and I will post the test procedure.
Sep 26, 2009 | Roper RAS6233KQ Top Load Washer
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
