Question about KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid error F3E1 main sensor shorted just replaced the sensor and still have the same error?
Whirlpool oven Super Capacity 465 error F3E1
The F3 E1 error indicates a problem with the oven temperature sensor or a short in the oven temperature circuit. To trouble-shoot this error, unplug the oven. Check the wiring harness for damage and then reconnect it, if it is undamaged. Next check the resistance across the oven temperature sensor. The resistance should be 1080 Ohms at room temperature. Replace the sensor of the resistance is not correct. Otherwise replace the main control board.
Please add a comment with the model of your oven if you want me to look up the parts list or diagram for your appliance.
I hope this helps.
Aug 05, 2017 | Whirlpool Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool washer F3 E1
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Jan 02, 2017 | Whirlpool Washing Machines
    Kemc377. Why is it showing error code?
    F1 DOOR SWITCH
    F2 KEYPAD
    F3 TEMPERATURE SENSOR
    F4 MEAT PROBE SHORTED
    F8 SELF CLEAN LATCH PROBLEM
    All other errors, replace the main oven control
    Aug 23, 2015 | KitchenAid Ovens
    Whirlpool range rf386pxd e1 f3
    The F3E1 error indicates that the oven temperature sensor is shorted. The part most be replaced.
    The sensor is part 8053344 for most models. See http://parts.sears.com/partsdirect/part-number/3148440/0022/664?keySuffixId=NA&brandId=1198&modelNumber=RF386PXDB0&productCategoryId=0124111&pathTaken=partSearch&pathRender=modelComponent&componentPartName=Unit&documentCompId=O2022127&diagramPageId=00004&blt=&prst=&shdMod= .
    There are several models of the Whirlpool range in the RF386PXD style. The parts lists can be found on many sites, including http://parts.sears.com/partsdirect/part-model/RF386PXD?prst=0&shdMod=RF386PXD . You may want to check the parts list for your exact model before ordering.
    I hope this helps.
    Nov 29, 2012 | Kitchen Ranges
    Error code f2
    see this causes and fix it. Read your instr.manual for codes. God bless you
    F2---Touch Panel Failure Check connections, Replace Control
    F2--Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking. Check oven temperature sensor for continuity. Replace if zero or infinite ohms.
    Sep 30, 2012 | KitchenAid Microwave Ovens
    Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
    Replace the sensor as shown in the F6 code
    F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
    Error Code: E4
    Cause: Shorted sensor
    Example: Disables cooking in affected oven
    Corrective Action: Check sensor
    Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
    F3 E1 error code
    Hi
    Thanks for using FixYa. Error F3-E1 in your kitchen aid means that the oven temperature sensor has shorted and to resolved this issue you’ll have to replace the oven temperature sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jul 05, 2010 | KitchenAid KGRT607 Gas Kitchen Range
    Kitchenaid DF Range F04 error code
    I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
    Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
    F5E1 error
    Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
    >>Exception Note:<<
    Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appear, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
    KitchenAid KGRA806PSS Gas Kitchen Range Logo
    197 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
