Question about Maytag SAV4655A Top Load Washer
Noise, leaks water
We have a maytag top load washer, model # sav4655ewq. it grinds when spinning, rinsing and leaks a little water at this time in the cycle. any thoughts? thanks, harry
  • 82 Answers
If it is doing this then sound like the bearing seal has gone and is leaking water into the bearings is the water brown or a grey in colour
Posted on Jun 28, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag PAV2300 Top Load Washer is nine years old. It just started making this LOUD grinding noise when it's washing, rinsing and spinning. What could it be?
I have the same type washer and it is about the same age makes the same grinding noise as the above mentioned one. Did this person ever find a solution?
Aug 31, 2010 | Maytag PAV2300 Top Load Washer
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag SAV4655A Top Load Washer Logo
172 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
