Question about LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer CE error message
Hello, could you please someone try to help me to solve this problem?
I have a washer LG WM-2277HW and when it is one rinse/spin show this message CE on display and stop working. I checked the filter on the front and looks clean, I removed all the clothes and still showing same message after few minutes working... any idea?? thanks a lot, Prado.
  • vprado Jul 01, 2009
    Any idea, clue??
  • vprado Jul 11, 2009
    Any expert?? Any Help?? I think the problem is with the board...but not sure...checked the cables, everything looks ok....
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Posted on Jul 23, 2009
What Does CE error code mean
LG's 'CE' states 'short circuit to motor or PCB' requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 11, 2011 | LG WM-2277HW Front Load Washer
The washer shows a UE error during the final spin. It does not reach the fast spin speeds, but shows the error after 5 minutes.
hello ue is an unbalanced error one of the first things you can do according to lg is click this link to try to aleviate the issue http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800 also check with a level that your unit is leveled if it is not then you would get this error code as well if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 21, 2011 | LG WM-2277HW Front Load Washer
An ue code flashing
Hello
UE is an imbalance error which is displayed when either the load is small or the appliance is tilted. You can also check if the washer is balanced and try unplugging the washer for 15 minutes to check if its balanced. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | LG WM-2277HW Front Load Washer
Code ce dont turn on
The CE error code is indicative of an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit, and refer to service
Thank You
Sep 12, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Jan 22, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
LG WM-2277HW Front Load Washer Logo
648 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
